Removed antenna, now what?
Old Jun 22, 2004 | 12:27 AM
firebirdjosh's Avatar
I removed the antenna from my car and have the gaping hole. Should I bondo it or weld a piece of scrap metal on it? Any ideas?
Old Jun 22, 2004 | 01:15 AM
JackZ.Twenty8's Avatar
I'd like to see you weld fiberglass. That would be interesting.
I'd fiberglass it, but only if you have the knowledge. If not, take it to someone who does!
Old Jun 22, 2004 | 01:33 AM
Tair's Avatar
I'm confused, was that supposed to be sarcasm? I thought the rear quarter panels were metal, not fiberglass.
Old Jun 22, 2004 | 08:06 AM
Zomie's Avatar
Yeah rear corners are metal, i thought they were aluminium. Hmm the best solution would be to weld a piece in that is cut right to size. using some tape on either side as u tac it. I am not sure it being Al and all.
Old Jun 22, 2004 | 09:26 AM
You, Good Sir, are a moron.
And my antenna is on the front fender, not rear quarter panel.
So I'll weld it if I can. Thanks.
Old Jun 22, 2004 | 11:18 AM
FLIPPINZ28's Avatar
okay i have shaved the antenna on a 92 camaro and my 94 i welded a washer in its place and then put bondo over it and smothed it in. of course i welded the washer on the inside of the fender and quarter panel well good luck
Old Jun 22, 2004 | 11:38 AM
AW/whiteZ-28's Avatar
The way I understand it is to do this:
1) get a piece of 18 gauge sheet metal
2) bend the sheet meta to the contour of the fender
3) trace the hole you plan on welding to the sheet metal
4) cut out the patch you traced
5) tape or magnet the piece in place
6) spot weld around the piece untill it's welded all the way around
go slowly so you don't warp the metal too much
7) grind the welds smooth
8) if it did warp work the metal smooth and straight again
9) prime and paint
Courtesy of "Trucks TV"
Old Jun 22, 2004 | 01:21 PM
Red96Lt1's Avatar
I saw that episode
wbspoon
Sep 19, 2015 08:12 AM
marlar98
Sep 19, 2015 07:53 AM
NewsBot
Sep 14, 2015 09:20 AM
RX Speed Works
Sep 11, 2015 03:31 PM
Bxlt1
Sep 10, 2015 08:16 AM
