Relocate traction control unit on lt1?
Old Sep 14, 2010 | 07:43 PM
MeenZ28's Avatar
Question Relocate traction control unit on lt1?
You LS1 guys have it easy, just tuck the thing away behind the computer. On the LT1 its mounted in the middle right above the driver side valve cover
Has anyone found a way to relocate it somewhere less sorethumbish? I understand the only way to delete it is to replace the whole throttle cable assembly and im not really looking to do that - just want a better place to stick it.
Old Sep 16, 2010 | 07:23 PM
MeenZ28's Avatar
Really? Am I that out of luck?
Old Sep 16, 2010 | 07:36 PM
94CamaroZ28/SSClone's Avatar
This should have been in the LT1 section, not the appearance section. This is why no one is replying to your thread!
Old Sep 16, 2010 | 09:33 PM
MeenZ28's Avatar
It's not really a technical issue though, it's for appearance sake...
Old Sep 17, 2010 | 11:43 AM
94 Camaro Z28's Avatar
I think what he is trying to get at is that all the "technical gurus" hang out in there so they would be quicker to give you an answer then folks in here.
Old Sep 17, 2010 | 12:09 PM
razor02097's Avatar
What all does it consist of? vacuum lines? throttle cables? Wires? I've never actually seen one in person.
Old Sep 17, 2010 | 12:13 PM
spcearle's Avatar
i took mine out of the bracket and stuffed it into an area on the right of the booster by the cowl.....i'll try to get pics of it but it tucks right in there
Old Sep 17, 2010 | 12:45 PM
6Speed's Avatar
I did the same thing. It took a little creative maneuvering to get it back there, but it will go.
Old Sep 17, 2010 | 04:03 PM
Yes you got it! Thanks.
Old Sep 18, 2010 | 10:54 AM
MeenZ28's Avatar
Noted. I apoligize. I rarely check the other forums other than the appearance and for sale sections...
No matter, I read a walk threw on how to deleate this thing and with the bonus I just got on Friday I'm going to ****** up a new throttle cable and be done with it. I always tun the TC off when I start the car anyway.
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
ddr698
Jan 9, 2015 10:05 AM
thenewkid
Nov 27, 2014 09:41 AM
Jul 4, 2005 05:00 PM
