R & R Z28 badges
Old Dec 15, 2002 | 07:18 PM
Grease's Avatar
R & R Z28 badges
I want to remove my fender and rear Z28 badges to get them painted silver coz the overlays I have on them right now are peeling off. What holds them on? Is it a self adhesive pad that I'll have to replace or are they held on my screws/studs/nuts?
Old Dec 15, 2002 | 08:10 PM
chesee48's Avatar
it is indeed an adhesive! One stock motha i might add =)
just take your time and take them off and get the sticky stuff out of the panel...thats the hardest part...cause it leaves nice imprints on the badges
Old Dec 15, 2002 | 10:03 PM
Grease's Avatar
In that case, you do you use to stick the emblems back on? Is there a replacement adhesive pad?
Thanks, Waswa
Old Dec 15, 2002 | 10:16 PM
Ernster500's Avatar
I wouldn't just pry them off, if I were you. I used fishing line to run between the car and the emblem. I tried floss, but the floss kept breaking.
You can use shoe goo to put them back on, or you can use 3M emblem tape, which you'll have to cut to size.
I used the shoe goo, but I used too much and had to take them back off. The shoe goo actually took the paint off the edges and I had to repaint them. I still have yet to put them back on.
Old Dec 15, 2002 | 11:18 PM
Pandamonkey's Avatar
That is some good infomation - I was just looking myself for some custom badges and was wondering what the best way to get the stocker's off.
Old Dec 16, 2002 | 03:09 PM
jg95z28's Avatar
Heat them up with an an old hair dryer first. Then you can basically pry them off with your fingers.
Old Dec 16, 2002 | 06:45 PM
Grease's Avatar
Thanks for the info guys
Waswa
F'n1996Z28SS
Aug 23, 2023 11:19 PM
stangspank
Nov 13, 2015 01:02 PM
jayblev95
Track Kill Stories
Jan 15, 2015 07:48 AM
