Questions about Halo headlights fr LS1 Camaro. Need a little help.
Old Sep 11, 2006 | 12:27 PM
RedBanditz28's Avatar
1) Would inspection give me any problems if i put these on my car? I live in NJ andthey can be pretty bad with nitpicking.
2) Do they fit well in the sockets? i mean do they look like they fit good?
3) How hard is it for a person to install them? I mean i was thinking of getting my mechanic to install them if i get them. Would an experienced mechanic be able to do this with ease? or would i need a exterior specialist of sorts?
4) Also, do halo lights shine brighter than stock headlights?
5) IF you buy halo lights as is, do they give off a regular white light at night or do they give off that bluish tinted light thats very vibrant and blinding to the oncoming car?
6) Lastly, should i get the halos over what i have now? Now, i have pro beam black headlight inserts and i like the way they look, but i look at these halos and they look awesome as well. Plus they are the actual light, and not a cover lense like the pro beams are.
these questions are pretty much in order of importance to the decision. Thanks
Old Sep 11, 2006 | 12:44 PM
shock6906's Avatar
Re: Questions about Halo headlights fr LS1 Camaro. Need a little help.
The halo lights should be really simple to install. The entire housing for your old headlights should pull right out and the halo setup should just stick right back in. I wouldn't bother getting your mechanic to do it, it's nothing you shouldn't be able to accomplish on your own in well under an hour. (that's if you take some pretty generous breaks) I can't really answer the other questions for you, but I doubt you'd have a problem with inspection.
Old Sep 11, 2006 | 12:45 PM
johnny6's Avatar
1) No they will not give you any problems, they are DOT approved.
2) Yes they fit great.
3) It took me about 30 minutes to install both, not very hard at all.
4) They shine better depending on the condition of your current lights.
5) It depends on what type of bulbs you purchase, you can always install regular white ones.
6) Yeah i would change them out just because the stockers get sun damaged too easly.
Brake_L8
Jan 20, 2015 09:44 AM
Deadbolt24
Jan 19, 2015 01:29 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
Hurin
Dec 13, 2014 07:38 PM
ChrisFrez
Nov 23, 2014 10:33 AM
