question about firebird door panels
Old Nov 17, 2003 | 01:22 AM
93formula's Avatar
i have regular firebird panels with roll up windows, so it has the flat speaker grill on it. im switching over to power windows soon and wanted the dual speaker pod style door panel, just wonderig if its possible to switch my map holder and flat speaker grill with that of the style of the dual speaker pod. just want to swithc the bottom piece not the whole panel, cant seem to find panels with cloth and dual speaker pods.
Old Nov 17, 2003 | 01:26 AM
ROADRAGE's Avatar
The plastic pieces are kind of melted into the panel. Im not sure if the parts will fit if you try and switch them, but it would be a PITA to do even if they did.
Old Nov 17, 2003 | 01:51 AM
93formula's Avatar
are they molded into the panel? i was hoping that it may be a two peice.
Old Nov 17, 2003 | 02:51 AM
ROADRAGE's Avatar
They are 2 piece. They can be taken apart pretty easily, the challenge is finding a way to put them back together.
Old Nov 17, 2003 | 09:38 PM
93formula's Avatar
thanks, ill just have to keep an eye out for the right door panels then, thanks
Old Nov 18, 2003 | 12:08 AM
v7guy's Avatar
I've done it and had alot of problems getting them right, in all honesty one popped loose a few days ago and I'm going to have to try to redo it.
you can try to melt the plastic and pull the panel through leaving the tab intact and then melt it back down, but it want's to break because it's now brittle from being heated up several times. Hot glue doesn't hold it, I have had some success with various Epoxies, but even that is difficult to get to work.
You can do it, it's just a bit of a pain
Brake_L8
Jan 20, 2015 09:44 AM
sscott
Jan 17, 2015 04:30 PM
siguy
Nov 27, 2014 10:07 AM
Roshambo
Sep 4, 2002 11:25 AM
MilkyClr69
Jul 29, 2002 10:01 AM
