Is it possible to switch a cloth insert with a vinyl on a 93-02 ta door panel?
I want to buy a Firebird door panel to replace mine but it comes with a cloth insert. I have the vinyl insert and it looks like once you cut the tabs that hold the insert on, you can't reattach it.
Re: Is it possible to switch a cloth insert with a vinyl on a 93-02 ta door panel?
If you do some searching on the net someone has a how to on changing the vinyl inserts on TA door panels. I remember finding it a long time ago.
just be carefully when you take the tabs off that you don't break the whole tab off. I tried to redo my Z's doors last weekend and I ended up ruining my passenger side door because I couldn't get it back together....needless to say it has superglue all over it now and so does the vinyl..looks horrible. I haven't given up on it yet, but I need to find a way to get to superglue off the outside of it
I would recommend to sand the tops of the plastic tabs off that way you have plenty of it left to super glue it back to or hot glue..whatever.
I found a link to the site i was talking about on www.projecttransam.com but when you click on the link it takes you to a different site. Maybe you can find it over there and contact the owner of the site and see if you can find it.
You can just cut the tabs that are melted bad...then use hot glue to reattach the panel. I replaced the carpet panel on my camaro with a dark grey vinyl panel.
-B
-B
guruerror
Jun 9, 2015 07:41 AM
