is it possible to replace just the headlamp lenses?
Old Nov 8, 2002 | 05:48 PM
vendela99's Avatar
hey guys, i just bought a new car and it's flawless except for the headlamp lenses are yellow and foggy. I want to replace them with some nice clear ones, and I was wondering if it's possible to just buy the lens and not the entire assembly, and where I can buy them, because the entire things cost $295 each.
Old Nov 9, 2002 | 07:25 AM
94BlackBowtie's Avatar
You just need to clean them up probably...there is some Dupont Polish that works real well (Dupont 1000 maybe???) but it should all come off...Might want to try the Show-n-shine section...someone in there would porbably know what would clean it best. I would at least try it before buying new ones.
Old Nov 9, 2002 | 11:24 AM
AW/whiteZ-28's Avatar
Piaa makes replacement lenses i just saw a catalog for that stuff yesterday at auto zone
Old Nov 9, 2002 | 12:25 PM
94TeALFiReBiRd's Avatar
yea i saw replacement head light lamps like cool blue ones at advanced auto parts and auto zone for like $25 a lense.
Old Nov 9, 2002 | 12:54 PM
vendela99's Avatar
Thanks a lot guys I appreciate it.
Old Dec 1, 2002 | 08:15 PM
KRUSS's Avatar
Headlamp Lens Replacements
Regarding the headlamp lens replacement, ALL composite (aerodynamic) lamps manufactured in the US since they were first approved for use by NHTSA in 1984 required that the lenses (glass of plastic) be permantently bonded to the housings. Chances are you'll have to replace the entire lamp (lens and housing assembly).
Regarding the yellowing of the lenses, it's most likely the hardcoating on the lens (sprayed onto the lens when manufactured to stabilize the plastic against abrasion and UV light) is bad. Typically, the ONLY solution is to replace the entire lamp. (Even if you are able to polish the yellow off the top layer of hardcoating, it's only a matter of time before it returns. Sorry.
QuickSilver02
Apr 7, 2015 11:12 AM
maybe2fast
Mar 16, 2015 09:45 AM
ChrisFrez
Feb 15, 2015 08:12 AM
97ss1826
Jul 23, 2002 09:48 AM
