pics of sub frame connnectors on a convertable?
Old Feb 29, 2004 | 09:29 PM
94YELLOWBIRD's Avatar
anyone have pics of the 'underside' of their convertabvle with some kind os SFC's installed
-KBDD's
-BMR's
-Global West
-SLP's
any brand is fine
thanks alot
nathan
Old Feb 29, 2004 | 10:17 PM
JoeliusZ28's Avatar
I dont know if theres any difference between verts and no-verts... but heres my kbdd's on my t-top that I just painted.
http://web.camaross.com/forums/showt...hreadid=230639
Old Feb 29, 2004 | 10:32 PM
i think there is a difference
every place i have seen has them for verts and another kind for hardtop/t-tops
DOES ANYONE KNOW THE DIFFERENCE IN THE TWO(VERT/T-TOP)
ANY PICS OF THE TWO NEXT TWO EACH OTHER
thanks
nathan
Old Feb 29, 2004 | 11:55 PM
lownslocamaro's Avatar
The vert undercarriage is different. Besides the floor having factory subframe connectors, it also has a different tunnel brace setup. I have the KBDD on mine and believe they are the best. The only issue is they hang down a bit lower on the verts so you loose some clearance but I'm lowered and have no major problems. Basically all the subframes you mentioned have a bar going between the pinch weld and the factory subframe connecting the lca bolt up to the front of the car. The real difference is that the KBDD connect the center of the car too, I think it helps but I have no real knowledge or comparison. No pics but go with KBDDs unless you want to run long tubes which I don't recommend on a vert anyway.
Richardan15
May 30, 2015 08:36 AM
Bruhdz
Mar 24, 2015 02:15 PM
WildRidez
Feb 23, 2015 07:24 PM
ChrisFrez
Feb 15, 2015 07:49 AM
Jul 4, 2005 05:00 PM
