perfect body panel alignment
Old Apr 1, 2007 | 11:51 AM
Brangeta's Avatar
I was looking around ebay (as usual) and found this '96 SS with only 1300 miles on it. If you look at the reflections in the paint between the body panels, you can tell this car has absolutely perfect body panel alignment. It really amazes me since my Z28 is looking pretty bad compared to this.
http://cgi.ebay.com/ebaymotors/1996-...QQcmdZViewItem
Is anyone here a body panel adjustment expert? I'd like to know how to make my rear bumper not sag. It's be awesome if my Z28 looked as good as this one.
Old Apr 1, 2007 | 09:59 PM
custom95's Avatar
Once again, another nice find. Nice job, that is one clean ss. I've never had any issue with my rear bumper sagging, but I've had it off a few times and one thing you could check is the little plastic pieces (similiar to the ones that are on the hatch interior panels). You know, the ones that you push in and they kinda lock into place. Anyhow, there are several (I believe four-2 on each side) that help hold the rear bumper into place and it might be possible that your's are worn out or have popped out. just a thought.
Old Apr 1, 2007 | 10:26 PM
Brangeta's Avatar
Good advice, I'll check that out sometime. My sister and I used to sit on the bumper at car shows back in the 90s, so maybe those parts are worn out.
Old Apr 1, 2007 | 11:54 PM
MarcR94v6's Avatar
Of course there's no way to really tell from pictures, but from whjat I can see, I'd say you're right.
Old Apr 2, 2007 | 07:52 AM
Brangeta's Avatar
Actually, you can tell a lot from pictures believe it or not. You may not have ever noticed this, but on our cars, if a panel is just slightly off, the reflection of the landscape will be wacky across panels. Look how perfectly the landscape flows from the front fender to the door in this pic.
Old Apr 2, 2007 | 04:40 PM
custom95's Avatar
I know for a fact that if you are not careful when jacking up the front of your f-body you can bend the hell out of the fender mount and that will lead to the appearance of the lower part of the fender being pushed out and not lining up with the door. Mine are pretty mangled from previous owner and it sucks.
Old Apr 2, 2007 | 07:00 PM
Brangeta's Avatar
Yeah, mine are mangled from, believe it or not, those lifts they use at Bridgestone and other tire places to quickly lift the cars up.
redleader
Parts Wanted
Nov 13, 2016 02:57 PM
CARiD
Feb 9, 2015 09:35 AM
redleader
Jan 22, 2015 12:05 PM
Queens94z28
Dec 20, 2014 09:11 PM
siguy
Nov 27, 2014 10:07 AM
