peeling clearcoat...ist there a fix?
Old Jun 24, 2003 | 02:00 PM
teke184's Avatar
i'm buying a car which has a small spot on the corner of the door that has the clear coat peeling...it's a spot the size of a quarter maybe...
is there a way to sand off that area...wet sand...then cover it so that the peeling stops? like maybe spraying the whole section of the door with another layer of clear?
thanks
Old Jun 24, 2003 | 06:19 PM
Whistler's Avatar
It will depend on what color it is and how bad it is clearing. If you flake off the clear with your fingernail and it keeps on peeling... you'll probably have to repaint the whole door. If you flake it off and it stops peeling at that small spot, then you can probably blend in a little clear in that spot.
Formula Steve
Sep 19, 2023 08:31 AM
magman
Apr 15, 2016 03:08 AM
WobblySausage
Oct 7, 2015 02:44 PM
Fatdog2
Sep 16, 2015 11:04 PM
Aaront810
Sep 11, 2015 11:24 AM
