Painting the Interior
Old Sep 28, 2007 | 01:48 PM
MasterZ28's Avatar
So has anyone painted any certain parts in the inside, i am currently working on several parts and pieces, but my biggest challenge of all is the center bottom half of the console. I bought a new one painted it and am wondering what is the best way to removing it? ANd show me some kick *** pics of what you guys done.
Old Oct 7, 2007 | 08:19 PM
lt1 beast's Avatar
my buddy painted parts of his mustang interior with vynil dye....when he told me he was going to do this i was shocked. It looked like crap the first coat them he add two more coats and its looks amazing...you can even paint leather with this stuff it works great and he didnt even wipe down the pannels before he sprayed them and it still has great adhesion with no chips
Old Oct 7, 2007 | 08:37 PM
Greed4Speed's Avatar
The vinyl dye will peel off.
Old Oct 7, 2007 | 08:56 PM
danhr's Avatar
the vinyl paint u can get at parts store is an easy quick fix, but will come off with age
rit dye works really well but is hard to do bigger pieces
Old Oct 7, 2007 | 09:03 PM
n2ceptor's Avatar
I suggest using SEM for plastic.... Works pretty good....
http://www.perfectfit.com/product.asp?Product_Id=154517
Old Oct 7, 2007 | 09:25 PM
Moshbmx1's Avatar
I had a local paint shop paint match my interior and they use Duplicolor paints and it worked perfectly
Old Oct 8, 2007 | 07:45 PM
Thats what I used on my dash trim. I sanded the trim pieces down then Duplicolor also has an adhesion promoter that I used as my base. I then went with a high build primer and then the color (a dark gray mettalic) and clear.
If you want pics I could snap a couple.
Old Oct 9, 2007 | 02:19 PM
Irish350's Avatar
snap away good sir!
Old Oct 9, 2007 | 04:45 PM
stroked 383's Avatar
I painted all of my interior plastic panels, and dyed the rest of what the paint couldn't stick to. Here is my thread:
http://web.camaross.com/forums/showthread.php?t=530817
I finally have my trans am door panels in too and I had to dye those as well...but I have found leather dye also dyes the plastic...just an FYI
Old Oct 9, 2007 | 11:13 PM
MasterZ28's Avatar
good stuff, now im wondering if i should change and get new carpet before i put everythign back? suggestions?
Old Oct 10, 2007 | 11:59 AM
Yes, if you are going to do something to your carpet, do it now...while everything is out! Trust me.
Old Oct 10, 2007 | 05:40 PM
What, and miss all the fun of rework?
Old Oct 10, 2007 | 08:02 PM
GALIATHON's Avatar
Same here i used good old spraypaint (duplicolor) Just make sure you clean the pieces first..
Old Oct 10, 2007 | 08:51 PM
Here are some thumbnails. Most are of the radio bezel because thats the largest part which makes it easier to see. I actually ended up having to sand this part down twice and repaint because my last clear coat layer didn't want to stick on the previous one. Second time around I just stuck with one clear coat.
Old Oct 10, 2007 | 10:02 PM
n2ceptor's Avatar
Greed4Speed, a shift light in the A/C duct????
