Painted LS1 Intake
Old Oct 16, 2007 | 06:03 PM
FiefSS's Avatar
Painted LS1 Intake
I've seen this around on a few cars before and I was just wondering if anyone had steps on how to do this? What paint, etc. I am just tossing this Idea around. Anyone have pics of theirs as well? Thanks!
Old Oct 17, 2007 | 10:02 AM
Greed4Speed's Avatar
I opted not to do this because w/all the tight corners in between the runners it would be a PITA to keep clean.
How I would go about it though would be to lightly sand it. Clean it with Acetone then clean it some more with alcohol. Let it dry. Use an adhesion promotor for plastic, then a layer or 2 of high build primer, color and then clear. All of this can be found at a parts store in spray cans if you don't have a gun and compressor.
Old Oct 17, 2007 | 10:11 AM
FiefSS's Avatar
Thanks for the reply. I am still debating if I will do this or not, my intake is almost always clean so its not too bad a of matter of keeping it clean just depends if I'll have some time to do it.
Old Oct 17, 2007 | 12:34 PM
Irish350's Avatar
a buddy of mine sanded the **** out of his (to remove the mold line circle things) and then sprayed it with this stuff called hammer coat... looks ****in nice.
Old Oct 17, 2007 | 04:12 PM
Just as a warning. I found out the hard way with hammer coat that a clear coat wouldn't stick. Hammer is cool if you want the texture.
Get some pictures of that intake Irish. I'd like to see it.
Old Oct 17, 2007 | 06:17 PM
Kwiksilverz28's Avatar
Been there, done it. Will be doing mine soon.... Clean, sand, prime, sand prime, repeat.....acrylic enamel top coat. Looks fantastic!
Old Oct 17, 2007 | 08:22 PM
FiefSS's Avatar
While the whites prolly not my favorite color that does look awesome. How has the paint held up?
Old Oct 17, 2007 | 09:12 PM
Good as far as I know. It did look awsome. I did it as a pro bono job for a friend. I will be spending more time on mine smoothing, filling in the EGR delete, yadda yadda. I will be painting mine silver matching the valve covers previously done. (It is actually the rim color, but I had the paint lying around.....I wished I had matched body color, but it will still look great!).
If you can't spray, get it smoothe as hell and primed, and pay someone to spray it...
Old Oct 18, 2007 | 06:42 AM
FiefSS's Avatar
Thanks again, I have one last question what paint exactly did you use. I see that duplicolor has acrylic enamels but none quite match the grey I was looking for. I plan to also try and match my wheels
Old Oct 18, 2007 | 08:15 AM
Get an LS6 intake if you're going to go through all that trouble.
Old Oct 18, 2007 | 08:53 AM
FiefSS's Avatar
I would.. but the minimal gain for my mostly stock motor plus the cost doesn't make sense right now. The car is fast enough for me now, I just want it to look a bit cleaner when I lift the hood.
Old Oct 18, 2007 | 11:04 AM
It may be a minimum PEAK gain at the moment, but you get nice under the curve gains even when stock.
It is also a mod you can build on.
Old Oct 18, 2007 | 01:02 PM
Irish350's Avatar
heres the best i have handy..
(kit car ftw )
Old Oct 18, 2007 | 06:49 PM
I was thinking about LS6 intake for mine too. Probably gain 10-15hp. Mine is fast enough with the blower till I build a stroker, and then I will go FAST 90.
Don't rattle can the paint if you are looking for show car stuff. You can not put enough material down right. Just prep and mask it. Take it to a shop, and they ought to be able to spray it for cheap. They will not warranty it as they did not do the prep, but who cares. I use rattle can primer, but I have a compressor, and spraying this small of stuff comes out perfect. The wheels I did look better than factory. I just don't have a booth for a whole car, so I do get some dust....
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
Brake_L8
Jan 20, 2015 09:44 AM
Jazsun
Dec 29, 2014 12:14 PM
