Paging 95Zdroptop (Custom Autometer gauges)
Old Sep 22, 2003 | 12:32 AM
pu12en12g's Avatar
I need to know:
- Which series of autometer gauges you got ?
- What type of led they take ?
- What type of LED you went with (standard vs. superbright) ?
- What color LED you went with ?
- How many LED's per pod ?
If anyone else knows any of the above... please post, thanks.
Old Sep 22, 2003 | 12:50 AM
95Zdroptop's Avatar
I just have the cheapest brand of White Face autometer gauges. Not sure what series but as long as they are white face it should work. 2 1/16 is the size.
The bulb size is 194 and only one is needed per gauge. This is the type of bulb I used
http://cgi.ebay.com/ebaymotors/ws/eB...category=33713
I think mine are superbright since they are pretty bright. I did not use any resistors either and they have been in there about 10 months. I am working on doing every interior light on the dash to be led. Its a little more complicated though. And I used blue leds
Old Sep 22, 2003 | 06:57 AM
94BlackBowtie's Avatar
I would say that they are pretty bright. As is the rest of the interior.
What I want to know is how hard was it to change the bulb in the Auto Meters? I would think it was a pain kind of, but I don't have mine yet, so I don't know.
You wouldn't need any resistors with this push in type because it is already built in to the base of those bulbs.
Old Sep 22, 2003 | 07:37 AM
pu12en12g's Avatar
Thanks man..
Yea the Quad LED's are the superbrights.... those look perfect.
One more question... which pods do you actually have, the mechanical ? or electrical ?
Also, is one of them a Air/Fuel ratio gauge because I thought the A/F ratio one cannot be lit up ?
Old Sep 22, 2003 | 09:08 AM
Originally posted by pu12en12g
Thanks Also, is one of them a Air/Fuel ratio gauge because I thought the A/F ratio one cannot be lit up ?
Don't think he has the A/F ratio gauge. Check out that pic I posted - both gauges have needles, the Auto Meter A/F ratio gauge doesn't.
Old Sep 22, 2003 | 10:01 AM
AW/whiteZ-28's Avatar
They do make a A/F gauge that uses a needle I'll see if I can find it so I can post a link
Old Sep 22, 2003 | 10:44 AM
95Zdroptop's Avatar
Well first off, the camera made the whole thing look brighter than actually is. The interior is actually a darker blue (which looks better than the picture) than what is shown but is still bright. Nothing to distract you while driving. I think it is awesome and it gets a lot of attention when driving espically with the top down.
94BlackBowtie (Thanks for recommending those pilot foglights)
I changed the bulb in about 5 minutes and that is because I had to take the gauge pod off the column and then get to them from the back while the wires where still hooked up. If you change the bulb before you install them that would be real easy. It is a little tight in there but nothing hard and I took nothing apart that I could remember.
pu12en12g
They are electrical and one of them is not air/fuel
Here are some gauges that look pretty cool!!
This one is new to me Pretty neat I think
http://cgi.ebay.com/ebaymotors/ws/eB...category=33676
I like this one but I got mine over two years ago so I may switch someday.
I also just used oil pressure for an example. Not sure of the quality of the gagues but if you are just going for looks then they are awesome.
Old Sep 22, 2003 | 11:24 AM
pu12en12g's Avatar
If you find that you officially will kick ***. I don't want the stupid Red / Yellow / green shiat.
Old Sep 22, 2003 | 07:48 PM
Couln't find a damned thing I wish I could remember where I saw it I'll keep looking though
Old Sep 22, 2003 | 10:12 PM
Ok I found 2 the one I saw greddy and another Tomei
here's a link to what the greddy looks like along with some others
http://www.alltrac.net/tuning/afgauge.html
but they are like 300 bucks
silver face
black face
white face
Old Sep 23, 2003 | 08:08 PM
pu12en12g's Avatar
Shiat. I was actually thinking the mechanical ones might be less expensive There goes that plan.
Good find tho ! ! Those are bad ***.
RUENUF
Mar 13, 2016 03:39 PM
99TransAmWS6
Feb 12, 2015 07:23 PM
Joes96z
Dec 13, 2014 07:48 PM
Burn_Out
Aug 18, 2002 08:49 AM
