opinions needed....
Old Oct 7, 2002 | 02:11 PM
pu12en12g's Avatar
opinions needed....
What do you guys think ?
I am not too sure about the grill, but otherwise I like it..
http://puren12g.com/conceptLS6.jpg
Old Oct 7, 2002 | 02:18 PM
HottZ4ME's Avatar
Yuck!
Old Oct 7, 2002 | 02:24 PM
pu12en12g's Avatar
Hott, can u be more specific ?
Old Oct 7, 2002 | 02:45 PM
HottZ4ME's Avatar
Sure.....everything from the grill to the windshield, I dislike, although the hood is ok.....
Overall, the car looks like a Camaro that needs to go on a diet! A little porky looking, to what should be a sleek car.
Just MHO.
Jeff
Old Oct 7, 2002 | 04:12 PM
ibanez6rg's Avatar
I guess I'll take the country road and say I like it It's different and the grill looks kinda weird but I wouldn't think twice about not getting one if I had the chance!
Old Oct 7, 2002 | 04:26 PM
anasazi's Avatar
get rid of the wheels
get rid of the truck grill
the ZZ's on the side need to be changed... don't remove them, just a smaller or flattened font
otherwise it don't look too bad
Old Oct 7, 2002 | 04:35 PM
AW/whiteZ-28's Avatar
Looks like a dodge stratus in other words
Old Oct 7, 2002 | 05:09 PM
pu12en12g's Avatar
Thanks for the input guys ! !
- Front grill inspired by the Stratus Touring car, (retaining the big mouth design would allow 2 front mounted Cold Air Intakes / Single Intercooler)
- Hood inspired by the SuperSport, Z style, and Ultra Z style hoods, with a more sleek / integrated design (design would allow both functional engine cooling and heat extraction at speed)
- Fully INTEGRATED bodykit (not a expensive option) inspired by the Callaway Supernatural C8, and HPI Nitro Camaro (would allow functional front brake cooling ducts, design allows for a stealth appearance without having to slam the car for a aerodynamic appearance/function, design also allows the car to be low and stealth yet not scrape the front on everything...)
- Headlamps modified to a more stealth design (concept would be 6000k HID as a standard safety feature)
- Removed keyholes (keyless entry would be so reliable that manual keyholes would no longer be needed, trunk would still have manual keyhole, and a switch inside, in the RARE event of a freeze up, which would trigger the door locks)
- Smaller door handles, with modified angle (to maintain sleek lines)
- All body lines smoothed, with only Minimized / Functional seams.
- Larger H4 6000k HID Fog lamps / DRL
- Turn Signals with small amber corners with otherwise crystal clear housings
- Engine would be Supercharged or LPE Turbo charged and LS6 based
- Wheels would be 19" standard with 30/35 series tires, modified rear and very mild fender roll. (Optional 20" wheels on the rear)
- Stiff spring rates but with standard Fully Adjustable QA1 shocks
- Gear ratios and rearend strength would be completely optimized for the N/A VS. the Turbo / Supercharged model, BUT would be a factory option. Engine would be modified to reliably handle 15-18psi but to bring HP ratings down would only have 6-8psi on the showroom floor.
Old Oct 7, 2002 | 05:13 PM
ibanez6rg's Avatar
I actually like the wheels. Doesn't Brent have those on his yellow SS?? Badass lookin'!
Ks0209
Oct 1, 2015 07:32 AM
drt
Sep 27, 2015 04:39 PM
SEOJustin
Sep 24, 2015 04:39 PM
jackpawt883
Jul 31, 2015 08:15 AM
birdblack
Jul 8, 2015 07:23 AM
