New Headlights?!
Old Nov 29, 2006 | 12:09 AM
mcalus's Avatar
New Headlights?!
I have a 1993 Z28 Camaro (LT1) I was wondering if anyone made any headlights that are Halogen or even physically look better than the stock ones. Someone told me that you can fit an 1996 Oldsmobile Cutlass Supreme headlight in place and you can find them on ebay....? tell me what you think.... thank you.
Old Nov 29, 2006 | 12:58 AM
Resilient94LT1's Avatar
I personally went with the Hella FF75 headlamp swap.
http://web.camaross.com/forums/showthread.php?t=473601
Old Nov 29, 2006 | 09:08 AM
shock6906's Avatar
Hey, now that's a cool picture!
Old Nov 29, 2006 | 10:49 AM
The Captain's Avatar
New wallpaper
Is that airbrushed on your actual hood, or is that just a photoshop pic? I cant tell the difference on this crappy monitor.
Old Nov 29, 2006 | 12:12 PM
It was done in PS, The Captain. If you would like, I can send you the 1280x960 or even a very high res 3072x2304 version.
Mcalus, I have more pictures from different angles of the Hella FF75's if you would like to see those.
Old Nov 29, 2006 | 07:10 PM
teke184's Avatar
you can always spend $40 on the harness upgrade which allows you to run 100w bulbs...then remove the bulb unit from the stock lights and install a set of 100w halogens
Old Nov 29, 2006 | 08:40 PM
Z95m6's Avatar
Yeah but those are still gonna suck. The problem is the stock housing/reflector. I have the Hella FF75's and they do look good but if i had to do it over again i'd go with the Hella 90mm's. I still might switch to the 90mm's because they just look so mean.
Old Nov 29, 2006 | 09:36 PM
mcalus's Avatar
Where can I buy some of these headlights from? I checked ebay and nothing came up?
Thanks.
Old Nov 29, 2006 | 09:47 PM
mcalus's Avatar
Never mind I found them on ebay I typed in Hella FF75's instead of Hella FF75.
does anyone know of any other headlights.
Old Nov 30, 2006 | 12:32 AM
tycar86's Avatar
Check this page out.
This is pretty old. Probably the two most popular are the FF75 and the 90mm. I also went with the FF75s.
Any more information can be found using the search function. There's tons of info in those threads.
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
