Need help installing new fender emblems.
Old Oct 14, 2004 | 06:00 PM
Tattooedlife's Avatar
Just bought 2 69 Camaro script Camaro emblems. The ones that have the studs to bolt through the fender. But the Year One book says you can shave off the studs and install with double sided tape. On my old 85 Camaro I used super glue (I beleive it was the gel kind) to install all the emblems. Has anybody used glue to install there fender emblems? I had no problem with it on my 85 Camaro, but just wanted to see if any body else has done this
Old Oct 14, 2004 | 09:48 PM
94Z28WP's Avatar
Re: Need help installing new fender emblems.
On my 81 Z28 I had chrome 350 emblems on each side of the air induction scoop.. I used automotive GOOP from Advance and it worked great.. I've also used it on trim and on one of my plastic Z28 emblems on my 94... Still holding strong... Just make sure you tape it up and let it dry overnight.
Old Oct 15, 2004 | 09:49 AM
kingman109's Avatar
i use rolls of industrial strength double stick 3m tape -
its paper thin and u stick emblem to it - then take x-acto knife and cut around - and peel off other side- leaves only the glue and will hold like hell too anything -
Nov 18, 2023 07:21 PM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
rocknroler69
Parts Wanted
Mar 22, 2015 04:41 PM
squarehead
Nov 21, 2014 08:02 PM
