My fiberglass dash pics
Nice looks just likt the one I did when I worte the write up on it except I tinted my primer black and layed down a silver base coat then a metallic blue mid coat and then 6 coats of clear before color sanding and buffing. Good work.
i took 40grit sand paper and tore the vinal all to hell then sliced it in spots so the fiberglass could soak into the foam under the vinal some people just remove the vinal but you dont haft to then i used a paintbrush and made the first layer then the second and third layer i added fiberglassmat then another layer of fiberglass then i mixed half bondo and half resin then put in on with a paint brush and added a little bondo to fill in some spots then sand with 180 then 300 then i primed it
cmsmith
May 25, 2015 07:49 PM
