Modify LT1 fuel rail covers for traction control module?
Old Apr 24, 2006 | 07:56 AM
MeanGreen97Z's Avatar
My 96 has the traction control module on the driver side of the intake and im wondering if anyone successfully modified a set of Corvette fuel rail covers to work around it. Is it a rough looking end product?
Old Apr 29, 2006 | 09:04 AM
PipesTA's Avatar
Re: Modify LT1 fuel rail covers for traction control module?
I would do the !TCS over modding the FRC.
Old May 1, 2006 | 01:02 AM
MeenZ28's Avatar
Any tips as to how to perform the !TCS mod?
Old May 1, 2006 | 03:42 AM
luckyou03's Avatar
you need a non traction controlled throttle cable. unbolt it, unplug it, and replace the throttle cable.
Old May 2, 2006 | 09:51 PM
Mr Z28's Avatar
Not that easy - you will loose your abs function - it is all tied in with the traction control module electronics
Old May 2, 2006 | 10:24 PM
LT1 POWR's Avatar
Cant you just relocate the TCS module to maybe underneith the cowl, like directly behind where it is. It looks like there is just a vaccuum line and an electrical conection so it shouldnt be that hard.
Has anybody ever done something like this?
Old May 3, 2006 | 01:05 AM
eagleknight97's Avatar
Good luck finding an answer on this one, ive been asking the same question since i joined, and still have yet to get a yes to the question and then pictures. Plenty of people have simply removed it, but at least on this site, no one has moved it to a better location on an LT1 car. The LS1 location wont work cuz of the power steering pump resevoir there. If you have an SS intake, then it seems like you could easily locate the TCS module where the stock intake runs.
Old May 16, 2006 | 12:47 AM
Mr Z28's Avatar
Re: UPDATE _ Modify LT1 fuel rail covers for traction control module?
UPDATE - I just finished installing these with the traction control module - I have yet to see anybody post pics of this completed on the board - I wondered for a while myself, and finally decided to just do it - the traction control module brackets just need to be notched around the same as a hose or like the alternator bracket.
It was actually quite easy - you just have to remove everything to start with, and then put stuff back on one piece at a time and keep cutting around each part that needs to get notched out.
Pics on page 4 http://groups.msn.com/GMsFbody/30thz28.msnw?Page=4
Old May 18, 2006 | 01:24 AM
MeenZ28's Avatar
You didnt happen to get some pics of the covers before installed so i can see the knotchs?
HectorM52
Jul 30, 2017 11:46 AM
Jlo
Feb 3, 2015 09:41 PM
ddr698
Jan 9, 2015 10:05 AM
siguy
Nov 27, 2014 10:07 AM
Jul 4, 2005 05:00 PM
