Lowering Questions?
Old Jun 22, 2003 | 06:11 PM
Zach94's Avatar
Question Lowering Questions?
I have a 99 3.8L Camaro. I just got 18" wheels and 245/40/18 tires put on. I want to lower my car 1.5 to 2 inches in the back and 1 to 1.5 inches in the front. Will there be any problems if i do this?(rubbing, etc.)? What all will i need to do this? Which springs and other parts are the best value?
Old Jun 22, 2003 | 09:02 PM
TA25th's Avatar
We need to know the width and offset of your wheels to give you a better idea.
You must have 18x8 wheels? (Just guessing from the tire size...)
What offset (or backspacing) are they?
-Shawn
Old Jun 23, 2003 | 12:10 AM
Zach94's Avatar
yea they are 18 x 8...but i have no idea on the backspacing
Old Jun 24, 2003 | 12:28 AM
Zach94's Avatar
anyone?
Old Jun 24, 2003 | 12:30 AM
TA25th's Avatar
If you can give me the backspacing or offset on the wheels, I can give you some good info...
-Shawn
Old Jun 24, 2003 | 12:35 AM
chuckys95's Avatar
yes!
offset/backspacing is key !
hmmm, are the wheels by chance "eagle" five spoke design ?
Old Jun 24, 2003 | 06:54 AM
Severous01's Avatar
the offspacing shouldnt matter too much...i dont think you will have a problem. the stock 16x8's dont even come close to rubbing when lowered, and 245-40-18 is the same diameter as 245-50-16. unless you have a reverse offset of like 50mm, then you might have a problem.
Old Jun 24, 2003 | 01:15 PM
Zach94's Avatar
The wheels are 18 x 8.5 Arelli Jovan's...i think the offset is +38 mm
Old Jun 25, 2003 | 12:22 AM
Zach94's Avatar
ttt
Old Jun 25, 2003 | 06:26 PM
Zach94's Avatar
ttt
Old Jun 25, 2003 | 08:48 PM
bruecksteve's Avatar
Your offset would have to be WAY off for 245's to rub. An 8.5" 38mm won't rub. I have 275's with Eibach Sportlines (they're for sale, I just added coilovers) on 17 x 9.5 46mm offset and I have no problems.
PS, nice wheels Chucky!!!
Side note: I just ordered a set of 17 x 9.5 38mm offset ZR-1's for the front for autocross, it should take those out about .5" more than my existing Borbet 46mm wheels which is exactly what it needed anyway. I always wondered why people didn't just make 17 x 10's with the proper offset instead of the 9.5's??
Old Jun 25, 2003 | 11:37 PM
Zach94's Avatar
If i get the Eibach Sportlines is there anything else i need to lower my car? or are the springs the only thing?
Old Jun 26, 2003 | 01:20 AM
Z28 97''s Avatar
Shocks are your Friend! I'd recommend getting some performace shocks when you lower your car.
Old Jun 26, 2003 | 06:19 AM
I second that. Get the very best you can afford. I use Koni Sport SA's in the front anf Bilstein HD's in the rear.
Old Jun 26, 2003 | 01:12 PM
Zach94's Avatar
What will happen if I just put on the Eibach sportline springs?
If i get shocks where is a good place to buy them?
where's a good place to buy the springs?
Are springs and shocks all i neeD?
