lowering question
Old Oct 16, 2002 | 12:21 AM
tbehling's Avatar
lowering question
what would i have to do to get my car this low
http://members.fbody.com/tbehling/206298_256_full.jpg
(copy and paste link)
Old Oct 16, 2002 | 12:28 AM
pu12en12g's Avatar
Coilovers + Low profile tires
or
Custom Airbag setup
(If you do this.... PLEASE get a camber correction kit )
Old Oct 16, 2002 | 12:34 AM
tbehling's Avatar
how do bags ride and perform, are they bouncy at all, and what am i looking at for a cost?
also, will i not beable to do that drop with spring alone, i would need coil-overs, what coil-overs can i get beside ground control, they are kinda pricey
Old Oct 16, 2002 | 12:41 AM
tbehling's Avatar
also,. the ground control kit says it only ranges from 0-2 inches o drop, wich could be obtainable with only springs, i am wanting near a 4 inch drop, oh what to do!
Old Oct 16, 2002 | 01:19 AM
Sniper33's Avatar
IMP I think that looks real ricey. But that's my own opinion and I'm not going to knock someone for what they like. Good luck!! Yes, and if you do that, definitely get ur chamber adjusted PLEASE!!!
Old Oct 16, 2002 | 02:06 AM
pu12en12g's Avatar
First of all, airbag setups are bouncy yes... and expensive as ****.
Secondly the owner DOES NOT drive that car lowered like that I guarantee it. MY car has a extreme drop, and I still am going to raise mine up some more (I am still experimenting with the ideal ride height for midwestern roads). It just isn't practical to DRIVE with that kind of extreme drop in a camaro.
Also, the ground control kit is +/- 2.5 inches.... PLUS upon installation the Ground Control Kit already lowers the car up to 1 inch. So the lowest I COULD presumably go right now would be a 3.5 inch total drop. Guess what... I dont WANT a 3.5 inch drop. Our cars just need slight tweaking, a body kit will give you more of the "slammed" / racecar look you might be going for, without sacrificing ride quality.
A Wings West body kit + 1 inch drop = Looks like a 3 inch drop.
Old Oct 16, 2002 | 03:22 AM
Bawls's Avatar
hrm good point.. maybe I should ditch the sportlines for the prokit...
Old Oct 16, 2002 | 10:21 AM
v7guy's Avatar
I agree too, it's not advisable to drop your car several inches, I'm running about an inch and a half with gfx and the car looks LOW. But is still driveable on alot of roads if your careful, and major roads with no problem really.
Old Oct 16, 2002 | 06:03 PM
dreamer1q's Avatar
Check the pics in the sig. I have a intrax drop, and ground effects. With the weight of the top, and the stereo equipment, it fell almost 3 1/2 inches, NON ADJUSTABLE. I drove it for 1 season. The springs come out this weekend. If you REALLY want to drop it that low, I suggest you find the cabbage and get the airbags. It is just a real pain if you cant get the clearance you need. Adjustable coil overs will work, but airbags will be faster and dont require you to get out of the car. Good luck, I thought I wanted low too. You might change your mind.
Old Oct 16, 2002 | 07:12 PM
Marky82's Avatar
Dreamer1Q how does your car ride with the ground effects and a drop. I got got some Enkei Winsomes (17x9.5) and I already have the WW W-type on my car, I was thinking about dropping her an inch to get rid of the wheel well space but I was worried about clearence. I ground out on every as it is already, how bad is it with the drop?
Old Oct 17, 2002 | 08:10 AM
dreamer1q's Avatar
The ride is much harder, and driveways suck. On the highway, even in Michigan, it isnt to bad. No real bottoming out on the E-ways, but backroads and entrances suck bad. Hence the changing of the springs this winter.
Noenav
Mar 1, 2019 07:38 AM
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
oldschool
Feb 9, 2016 09:21 PM
HectorM52
Jan 31, 2015 07:29 PM
