Losing my antenna
Old Aug 30, 2006 | 11:31 AM
My Red 93Z-28's Avatar
Losing my antenna
Wasn't sure if I should post this here or in electronics, but I was wanting to get rid of my antenna, to make the car look a little cleaner once it gets painted. But I didn't know if there was some type of hidden antenna I could purchase so that I could still pick up radio stations. Anyone know for sure? Thanks in Advance.
-Justin
Old Aug 30, 2006 | 01:42 PM
Meatyshells's Avatar
Re: Losing my antenna
im pretty sure they have motarized ones that you can get off rksport.com or ebay
Old Aug 30, 2006 | 02:26 PM
LT1 POWR's Avatar
If you are talking about shaveing the antenna, then there are antennas that you can stick on your rear window so you can still get reception, or you could switch to XM or something. But i am running without any antenna at all and i still get great reception. I just have whats left of the original mounting bracket that is connected to the radio stuffed up by where my spare was.
Old Aug 30, 2006 | 04:48 PM
CamaroRacing12's Avatar
is the actual shaving of the antenna mount hard? lots of body work?
Old Aug 30, 2006 | 06:06 PM
Do you know where I can get an antenna to stick on the inside of my rear window?
I'm not sure how much body work it involves, but my car is getting painted and needs quite a bit of body work already. I don't think it is too hard, but not for sure.
Old Aug 30, 2006 | 07:55 PM
kameleon426's Avatar
check out this antenna. i have it on my 93 integra and works great i just mounted it under the dash with the double side tape and hooked it up to my deck and that was it.
http://www.crutchfield.com/S-k5hUXGt...na&i=12044UA20
Old Aug 30, 2006 | 10:00 PM
oneslowz28's Avatar
i shaved my antenna and bought a low profile one that mounts int he top of my hatch on the inside. it only coat like 30 bucks and i get better reciption now than before with the stock one.
the body work isnt hard if your going to weld a "filler" plate in now if you want to use bondo your going to have to lay some fiberglass mat under the hole and once its dry then fill the top with bondo.
Old Aug 30, 2006 | 10:15 PM
LT1 POWR's Avatar
What i did was cut a piece of metal the size and shape of the hole where the antena mount was, weld that in, grind it down to match the body, bondo it smooth it down, primer it, and paint. Looks great, cant even tell the car had an antenna in the first place. I think best buy has those window mounted antennas, im sure a car audio store would have them too.
Old Aug 30, 2006 | 10:32 PM
oneslowz28's Avatar
thats what i did.
Old Aug 30, 2006 | 11:29 PM
Thanks for all the replies, I'm definately going to do that now.
Old Aug 31, 2006 | 12:23 AM
95custom's Avatar
Originally Posted by oneslowz28
thats what i did.
I did that too!... were brothers
Old Sep 1, 2006 | 12:54 PM
RacingTiger04's Avatar
same route i went too, works great. Between me and my grandfather it took all of 30 minutes to do.. including finding somehting to weld in that hole lol. definately worth the little effort, makes a much cleaner look on that rear pass. fender as far as a replacement i always have too many cds in my car to choose from so ive never listened to the radio once, just left mine off completely *shrug*
football4life
Oct 4, 2015 07:48 AM
95z_28_camaro_4_Ivan
Oct 3, 2015 07:27 PM
Bxlt1
Sep 10, 2015 08:16 AM
Bxlt1
Jul 18, 2015 02:48 PM
