lights
Old Mar 13, 2004 | 01:54 AM
Geezer powered's Avatar
lights
can you run a hi-beam bulb in the low beam position?
Old Mar 13, 2004 | 06:27 PM
AW/whiteZ-28's Avatar
Plugs are different just enough so you can't do that
Old Mar 13, 2004 | 06:29 PM
EbeZ28's Avatar
Unless of course you buy a 9005 wiring harness from NAPA ($5-$10), Shucks or wherever. Then you can switch 'em.
Old Mar 15, 2004 | 07:35 AM
94BlackBowtie's Avatar
I did that - didn't notice a good difference. The high beam pattern is a lot more diffused. I would either stick the stock way - or go totally aftermarket.
Old Mar 16, 2004 | 05:18 PM
PediDr2's Avatar
Very easy to Dremel down the ribs in the connector and make the hi and low plugs universal. I did it that way because when I upgraded my harness I switched two of the connectors. DOH.
They should snap together fine with the ribs removed.
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
