LED's for clear corners
Originally posted by 94BlackBowtie
Click me...
Click me...
With LED bulbs, you need to swap out the flashers in order for the turn signals and hazards to function.
You need 2 Triton EL12 electronic flashers. They can be bought at Autozone for $7.99 each. One is for the turn signal flasher, the other is for the hazard flasher.
The flashers are located behind the dash panel below the steering column, about a foot on either side of the steering column. Just look for little clips... you won't really be able to see the flashers, but just reach behind where a clip is and your hand will be on the flasher.
I've done this in my car and it works great.
Click me...
Click me...
Originally posted by stik6shift98
do they look better then stock????
They're not as bright as regular bulbs, but the hyperwhite LEDs match my quasi-HID bulbs perfectly.
PIAA 3157 bulbs will be much brighter than the LED's will be and will match the color temperature of most of the hids out there. They give off a white light with a slightly bluish hue... the same thing the LED"s do. I had the LED's in my car for almost 2 days before I took them back out. Not a good replacement for turn signals in my opinion.
If anyone here is interested I have a set of 3157 and 194 LED bulbs in Amber color. I bought these, but found a better deal on PIAA's. They cost me $30 and they are brand new so $20 shipped? Email me
