LED Taillights
Old Jan 14, 2007 | 01:25 PM
30thZ286speed's Avatar
LED Taillights
Does anybody have LED taillights? I saw some new LED replacement bulbs that have a multiple LEDs at differnet angles that way they can take advantage of the reflector housings in stock taillght applications.
Anybody have pics.?
Old Jan 14, 2007 | 01:45 PM
roadkillZ28's Avatar
where did you see these lights?
long time I saw them in ebay, custom made I believed, I'm looking for these LEDs long time you can find 3876453x10000 type of leds for civics or other cars but NOT for camaro
Old Jan 14, 2007 | 04:46 PM
Evil Lord Lucas's Avatar
I've seen those bulbs too; been thinkin bout gettin them.
Old Jan 16, 2007 | 02:13 PM
Craddock's Avatar
My local Advance has replacement bulbs that are leds. It's about 10 dollars for the 194 bulb replacements. I don't know the price for the rest cause that was what I needed. They're in the ricer section.
Old Jan 16, 2007 | 02:15 PM
Craddock's Avatar
I didn't get them by the way. So I can't tell you how well they do at lighting.
Old Jan 16, 2007 | 03:14 PM
Brent94Z's Avatar
Super Moderator
They don't show up that great during the day. Here are some pics of my old Trans Am. Taillights are even clear (red plastic removed then taillights re-assembled).
Old Jan 16, 2007 | 08:40 PM
shock6906's Avatar
They'd probably show up a little better in those clear housings if the plastic was roughed up. The light's just shining right through that plastic and not being absorbed by it.
Old Jan 18, 2007 | 07:26 PM
jeff_is_sexy's Avatar
I second what shock said.
Don't get me wrong; those lenses look really neat (you did an awesome job), but I have a feeling they probably look home-made when they are lit up in the dark. If you roughed the plastic up a bit, maybe from the inside, it would give a uniform distrubution of the light and it would look very cool.
Old Jan 19, 2007 | 09:17 PM
TheV6Bird's Avatar
http://www.superbrightleds.com/
I have LEDs on my rear sidemarkers (the lens is clear). The light also doesn't show up well during the day, but at night they look great.
I like LEDs because they light up brighter and faster, and last longer than the regular bulbs. They also give a richer color look to them.
Old Jan 19, 2007 | 11:35 PM
igobuk's Avatar
LED's have very focused light. They do not light up entire housings well at all. Even in our gauge clusters, you need the 5 LED bulbs just to fill in the cluster. The only decent way to do the tails would be to open 'em up and lay out dozens of individual LED's in a grid pattern of sorts. Other than that, a simple bulb swap will look crappy.
Old Feb 27, 2008 | 02:19 AM
Black_97'Z's Avatar
Sorry to dig this thread up but I found that superbrightleds.com now has these...
They are supposed to disperse the light sideways and forward. So with 24 red LED bulbs shining through a red lends, wouldn't the light be brighter than using the regular LED bulb set-up? Or should I use white LEDs, since the red lenses will absorb the light from the red LEDs? I am really thinking about getting these for my brake lights and back-up lights, but if you can't see my brake lights during the day what’s the use.
Old Feb 27, 2008 | 12:57 PM
eagleknight97's Avatar
This company has some excellent bulbs that are very bright and great at dispersing light
http://www.v-leds.com/Shop/Control/f...m/1/menu_num/2
Old Mar 5, 2008 | 10:30 PM
Yes if you have red taillight lens, go with white/clear LEDs, it will be much brighter.
Old Mar 19, 2008 | 02:42 PM
Found these on eBay when I was looking for a new chrome front badge.
They would look better without those circles and with a black backing instead of chrome, but these are the first true LED tails I've seen for an F-body.
http://cgi.ebay.com/ebaymotors/93-02...spagenameZWDVW
I just found some with a red lens also. These look ten times better. They also had them in a smoke lens color, but I can't find any with the black backing. http://cgi.ebay.com/ebaymotors/93-98...spagenameZWDVW
And here's some with the black backing. I may actually put these on my car. I doubt it, but I'm considering it.
http://cgi.ebay.com/ebaymotors/98-02...ayphotohosting
Aug 24, 2015 11:04 PM
cardemo16
Aug 24, 2015 01:04 AM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
karguy16
Mar 6, 2015 01:31 AM
