LED questions...
Old Jun 23, 2004 | 10:14 PM
MustangEater82's Avatar
LED questions...
1st where do you get them, I know ebay is much better then radioshack. Any other places you suggest? Any specific sellers? Also I don'tknow much abotu leds but is there anything I shoudl look for in hooking them up to a 12 volt system? Any specific requirement that the LED must meet?
thanks
Old Jun 24, 2004 | 12:05 AM
BigggD222's Avatar
Looking at this big sticker on my comp, superbrightleds.com, I'm pretty they have wiring diagrams on there too!
Old Jun 24, 2004 | 12:59 AM
AW/whiteZ-28's Avatar
Well depends on what you want to do with the leds for me to tell you where to get them.
If you are replacing bulbs go to www.superbrightleds.com like the guy above said.
If you are doing custom led stuff and have to make something with them go on ebay and search for this seller "cwithk" or go to his/her ebay store http://stores.ebay.com/Chi-Wing-LED-product-shop make sure you get the ones that come with resistors.
If you need me to go into more dtail on the ebay ones post up
Old Jun 24, 2004 | 01:34 AM
I am looking into doing custom stuff....
does it matter what size resistor, or is it generic?
Also any links to sites that have a little more info, I have some small electrical expereince in cars, but looking to learn more
Old Jun 24, 2004 | 06:19 AM
97FormulaWS-6's Avatar
What exactly do you want to know....
Most typical 5mm LEDs are 2 Volt devices, they need to have a resistor wired in-line with then to drop the extra voltage. For each LED you will need a 470 ohm to 1K ohm resistor. This rule changes a little if you are going to hook more than 1 LED in a string.
95% of the time I get my stuff off Ebay, they are the cheapest for the LEDs. The resistors you can get locally at radioshack, but they are cheaper on ebay as well.
For a resistor you want the value that I stated earlier, with a rating of 1/4W. That should work fine.
If you have any further questions let me know, I design LED Lighting fixture for a living.
Old Jun 24, 2004 | 11:57 AM
Just get the ones off ebay then look for the auctions that come with resistors they will throw the right ones in there for you.
You just have to solder them.
I bought 100 and I still got like 90 left
Old Jun 24, 2004 | 02:54 PM
firebirdjosh's Avatar
www.mouser.com
www.digikey.com
Both should have plenty of LEDs for you.
www.smallbearelec.com
The value resistor matters alot, just as much as the color and voltage of the resistor. Red LEDs need a bit more juice than a blue LED to be the same brightness.
2K2 with a red works great for 9V.
Old Jun 25, 2004 | 11:59 AM
PDCamaro318's Avatar
Eric if you don't mind me asking what are you making?
Old Jul 2, 2004 | 02:08 AM
Tair's Avatar
Lite-Brite?
Old Jul 2, 2004 | 09:26 PM
Originally posted by Tair
Lite-Brite?
On a lighter note I would like to wish all a Happy 4th of July and don't do too much stupid stuff
Aug 24, 2015 11:04 PM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
ryan2
Feb 21, 2003 01:03 PM
