Led lights
Old Jul 29, 2006 | 01:02 PM
obaja's Avatar
Led lights
1. has anybody put in led light bulbs for there turn signals? Any problems with blinking faster or slower or SES light coming on?
2. has anybody put in led light bulbs for there brake lights? any problems likewise?
Old Jul 29, 2006 | 01:24 PM
97FormulaWS-6's Avatar
Re: Led lights
You need an electronic flasher unit which is load independent to run LEDs in those spots. The factory unit is a thermal unit, and won't work properly with LEDs.
The only issue with the tail/brake lights, are the ones available are no wheres near as bright as the factory ones.
Old Jul 30, 2006 | 08:35 PM
igobuk's Avatar
Re: Led lights
You can use LED bulbs as long as you splice in some resistors on the wires that bring power to the bulbs. Just test the standard bulb's resistance and go to Radio Shack and buy that resistor, usually just a few hundred ohms does it.
But like mentioned above, the LED bulbs will not fill out the whole lense with light like a regular bulb does because LED's tend to have focused lighting. If you get them for the front, it won't matter too much because it's a relatively small lense to light up which is pretty much focused forward anyway. But in the rear, you'll end up with a red lense and a red circle in the middle lighting up the same diamter as the bulb and not much else.
There are newer bulbs that have more LED's light up the sides as well as the front but I have not used these so I don't know how those would look.
Old Jul 30, 2006 | 08:57 PM
obaja's Avatar
Re: Led lights
Thank you for the help, i will look more into this
Old Jul 30, 2006 | 09:20 PM
jtblckmaro's Avatar
Re: Led lights
superbrightleds.com sells plug in bulb replacements. That's who I'm gonna go with as soon as I get time to get to it.
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
Jan 23, 2015 01:13 PM
Injuneer
Advanced Tech
Jan 15, 2015 02:49 PM
