interior problem
Old Oct 31, 2006 | 01:37 PM
GoFast908Z's Avatar
Member
interior problem
how do you keep the seatbelt from rubbing on the side of the headrest on TA seats? The edge of my seatbelt is starting to cut into the leather and wear it off. I spent a lot of money on these seats and don't want to see them ruined. Here is a pic of where the belt is sitting. Also, that is the proper placement of the seatbelt guide.
Old Oct 31, 2006 | 04:14 PM
baddboy1705's Avatar
aaaaaa...good luck with this one... been trying to figure a way for myself
Old Oct 31, 2006 | 04:27 PM
PSU 98's Avatar
You could get those seatbelt cushions like the ricers and serious racers use and just put them higher up on the belt.
Old Oct 31, 2006 | 07:11 PM
GoFast908Z's Avatar
Member
nah, that won't work
Old Oct 31, 2006 | 11:23 PM
shock6906's Avatar
5 point harness? It's a little extreme, I know.
Old Nov 1, 2006 | 12:44 AM
Brangeta's Avatar
Can you not mount the guide on the actual seat instead of the headrest? I know it will lower the belt, so you will have to see if it would actually still protect you in a crash by going over your shoulder...
Old Nov 1, 2006 | 01:40 AM
shock6906's Avatar
By now he already has two screw holes in his headrest so without taking the car back to the upholstery shop to have that panel replace, he's basically stuck with the guide where it is. Looks like the best thing you can do is put maybe a clear vinyl cover over your headrest, kinda like your grandmas slip-covers on her couch.
Old Nov 1, 2006 | 01:51 AM
GoFast908Z's Avatar
Member
there is a support inside the headrest to support the seatbelt screws in a crash. Nothing in the seat could do that, plus it would look really wierd.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
cmsmith
Mar 24, 2015 02:28 PM
InfernalVortex
Jan 17, 2015 09:35 AM
