Interior lighting OUT!
Old Mar 24, 2003 | 09:36 AM
jare23's Avatar
just before i start messing around with some of the stuff i shouldn't be i was curious to be sure that its just a fuse that i need to replace on my car or what? my HVAC lights went out alond with my shift panel light as well as the light under neath my light ****. is this a fuse or something else?
Old Mar 24, 2003 | 12:40 PM
AW/whiteZ-28's Avatar
Its a fuse
Inside of you car driver side take the little panel off on the side of the dash look for something called gauges or something to that effect hope that helps
Old Mar 24, 2003 | 01:11 PM
jare23's Avatar
ill be replacing the fuse after i get out of school but was curious where in fort worth are you located? im 10 min. east of dallas and was just curious where all the other f-body's on here were in my area. got any pics of your car as well? laterz
Old Mar 24, 2003 | 02:28 PM
I'm in north fortworth North richland hills sorry though I dont have a digi cam so no pics yet
Old Mar 24, 2003 | 02:43 PM
jare23's Avatar
i dont know whats up with my car now. i just checked all of the fuses and their still all good. anyone have any ideas?
Old Mar 24, 2003 | 03:03 PM
Did you try the DIMMER fuse?
That turns all the lights you said are going off, in my car
when I pull it...
Old Mar 24, 2003 | 03:50 PM
tbyrne's Avatar
All of the interior lights are out in one of my Camaros. The dash is fine, it's just the interor lighting that is out. The fuses look good and I haven't had a chance to chase it down after that.
Old Mar 24, 2003 | 06:03 PM
snorkelface's Avatar
Pull off the trim panel that covers the drivers side kick panel (close to where your hood latch is). There is a ground post behind it. Make sure all the grounds are secure.
Old Mar 24, 2003 | 09:55 PM
jare23's Avatar
ill go check the dimmer now. ill brb to let you know whats up with it.
Old Mar 24, 2003 | 10:21 PM
jare23's Avatar
thanks to all who have posted. i figured out what it was. was nothing to do with any type of fuse or ground of any sort just plain old stupidity which i seem to have a constant supply of. when i put in my overlays about a month ago it came with its own dimmer with the blue/green light switch with instructions to not use the stock dimmer for the new overlays. so i guess i never payed attention that one time when i turned off my headlights that i turned off the stock dimmer all in one. d@mn do i feel stupid.
Old Mar 25, 2003 | 10:10 AM
Talking
Hehe, don't feel bad. That happens to everyone at least once in awhile.
RUENUF
May 25, 2016 08:10 PM
RUENUF
Mar 13, 2016 03:39 PM
silvermansteve
Mar 4, 2015 05:02 PM
Collector Car
Jan 5, 2015 10:58 AM
squarehead
Nov 21, 2014 08:02 PM
