Interior Lighting / Bulbs
Old Feb 18, 2007 | 03:28 PM
MasterEvilAce's Avatar
Anyone know any details on replacing the interior lighting elements, with colored bulbs.. preferrably LED bulbs if they would work.
How many locations are there, and are all the bulbs the same size?
I'd like to go with a light orange color to match the exterior, and hopefully to go brighter, as well.
The locations I can think of are the door panels (the switch lighting).. the dome light, and the mirror lights on the front. What else is there? I'm not looking to touch any of the gauges or anything like that.
Old Feb 18, 2007 | 04:31 PM
BlackbirdWS6's Avatar
well I have mine everywhere except the dash. This includes the door panels, courtesy, map lights, trunk light, ash tray, and a dome light(if I had one). I'm working on the rest of the exterior. I just ordered a bunch so should be interesting.
-brian
Old Feb 18, 2007 | 04:44 PM
are you using LEDs? Can you give me some more information on where to order, and what to order?
Old Feb 18, 2007 | 09:45 PM
I am using LEDS for all the lighting that I mentioned. The vendor that I buy the LED's from is not a sponsor so I will PM that to you. I recommend using the lighting guide from sylvania.com to find which replacement lamps you need. You simply match up the style lamp to an LED replacement and there you go. The trick is to take note of which LED configuration will illuminate the best per the application. LEDs are directional so picking the proper cluster config is important to get positive results.
-brian
Old Feb 19, 2007 | 01:54 AM
Bayer-Z28's Avatar
http://www.whitegauges.net/whitegaug...&productsID=27
THey have the LED lights.. As far as LED bulb replacements..
mattstrike
Mar 24, 2015 02:11 PM
silvermansteve
Mar 4, 2015 05:02 PM
squarehead
Nov 21, 2014 08:02 PM
