INSTALL Trans am side skirts on a firebird!
Old Mar 15, 2003 | 08:54 AM
TECHNOBETSY's Avatar
Talking INSTALL Trans am side skirts on a firebird!
Just got a set of Trans am ground effects (side skirts) and i want to install them on my firebird. the question is HOW and i see all the little black clips around the ground effects, do i have to drill about 6 or 7 holes on my car? how about the two holes on the bottom if you know what i am talking about...
any tips or hint will be helpful
THANKS
P.S. one of the pieces got couple clips missing, can i use some dubleside tape to stick it on?
Old Mar 16, 2003 | 09:15 PM
onoiocoko's Avatar
im not sure, but where the ones off the TA the rocker panel? because u might have to take the firebird rocker panel off and put the TA one on. im not sure i drive a maro but if ur not sure its a cover u might have to take the firebird one off? anyone know?
Old Mar 16, 2003 | 09:24 PM
1994TransAm's Avatar
you will have to drill holes in your rocker panel...so be careful!!!!
they pop in with the clips... the front of the GFX has a bracket that mounts inside the lower back portion of the fender..
good luck... i know how to remove them..but not install them on a car that never had them....
a dealership would be a good thing or maybe a shop.... cuz if they screw up drilling or break something...its their fault not yours
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Brake_L8
Jan 20, 2015 09:44 AM
siguy
Nov 27, 2014 10:07 AM
