indiglo gauges
Old Jan 8, 2007 | 10:58 PM
reamo04's Avatar
indiglo gauges
http://cgi.ebay.com/ebaymotors/i505-...QQcmdZViewItem
how hard would something like that be to install?
Im looking at getting autometer C2 series gauges, and that would match almost perfectly
edit: do the stock panels have a bulb behind them or a LED? Can I change the bulb color to get blue numbers (what i want)
Old Jan 8, 2007 | 11:13 PM
custom95's Avatar
I installed some white face gauges and they weren't too bad. Make sure that you mark where all of the needles sit at when the ignition is turned on or it can be a real beeyaatch to get them back to where they should be- I speak from experience. Other than that the install was pretty straight forward- good luck.
Old Jan 9, 2007 | 08:51 AM
shock6906's Avatar
I put a set in my car and didn't have to pull the needles off. You've got to do some fancy bending and turning of the overlays, but with some patience, it can be done.
Old Jan 9, 2007 | 12:58 PM
94maro's Avatar
...x2
Old Jan 9, 2007 | 04:09 PM
reamo04's Avatar
yeah, where did u guys get urs from?
Old Jan 9, 2007 | 04:27 PM
94maro's Avatar
i got mine off of ebay...it lasted about a year and a half then i found the MacEwen over lay and opted for it instead
Old Jan 9, 2007 | 06:13 PM
96' TransAm LT1's Avatar
they suck... bad. i had mine on for about a month, and they went out
Old Jan 9, 2007 | 08:50 PM
shock6906's Avatar
Mine are a pain sometimes. They're not exactly the most reliable thing I've got in my car. Sometimes they turn on right away, other times you have to play with 'em to get them to light up. Mine were from eBay.
Old Jan 9, 2007 | 09:17 PM
reamo04's Avatar
im looking at NR gauges from fbodymotorsports.com
kinda pricey, but i believe u get what u pay for.
http://www.fbodymotorsports.com/inc/sdetail/9649. these are just inlays,
can i just change bulb color on the stock panel?
Formula Steve
Sep 19, 2023 08:31 AM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
themex2002
Sep 2, 2015 03:47 PM
