HyperWhite Lights
Old Oct 6, 2002 | 05:55 PM
93Z286Speed's Avatar
HyperWhite Lights
Do they make any sort of hyperwhite bulbs for 93-97 camaros.. ALSO where can i get clear corners cheap? i want em wit purple bulbs bad!
Old Oct 6, 2002 | 07:00 PM
FirehawkNS's Avatar
I have seen a kit that gives you the ability to run hyperwhites, but the kit was $300 (saw it 2-3 years ago, couldn't tell you where), I was not willing to pay so I took my factory bulbs, cut out the light, cleaned off the silicon that silled it. Then I bought the hyperwhites that fit the 98+, got some high temp silicon, lined the bulb up and sealed it off using the silicon (lots of it) to seal it. Had the only 94 camaro with hyperwhites. They are also cheaper for me since I am friends with guys at the local speed shops. Ran them like that for about 2 years (replacing bulbs when needed of course), no trouble. Need any help e-mail me. Good luck
Old Oct 6, 2002 | 07:23 PM
pu12en12g's Avatar
Re: HyperWhite Lights
1) Yes they make 9006 (low beam) and 9005 (high beam)hyperwhite bulbs for your stock housings. As mentioned above, you WILL have to silicone them into the stock housings.
2) Best prices for clear corners are usually on ebay.com
3) Purple turn signals will be illegal , but yes you can get purple 3157 bulbs.
Old Oct 6, 2002 | 09:42 PM
why are purple signals illegal and not white.. also couldnt i have purple running lights and then the turn signal bulb be white?
Old Oct 6, 2002 | 10:05 PM
pu12en12g's Avatar
White ones aren't legal either I
I'm actually working on a way to make my setup street legal. I want white DRL's and Amber turn signals...
dluna333
15
Mar 13, 2015 12:30 PM
STR FTR 1
3rd Gen / L98 Engine Tech
Feb 10, 2015 10:36 PM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
