hyperwhite fogs, drl, and headlights
Old Feb 17, 2003 | 06:07 PM
mosskeet's Avatar
I am planning on upgrading all of my lights to hyperwhite. The bulbs I currently have in my drl's look kinda yellow. One of my fog bulbs is out so i need to replace those anyway. What I want to do is put hyperwhite bulbs in all of my lights, but I want all of these bulbs to match. I dont want some of them white, others with a yellow tint, and others with blue tint. I need all of the bulbs to match. I also dont want to have to alter my wires any and I would like to avoid bulbs that will melt my clear corners. Do any of you guys have any suggestions on a company that makes bulbs that I can get to match in all of these applications?
Old Feb 18, 2003 | 12:07 AM
BadBowtie93Z28's Avatar
Cuzo
Cuzo....They are a JapaneseCompany.I have their Headlights,DRL,Reverse, Fogs, and Rear Markers. They have them at a place here called Extreme Auto Accessories. They are kinda expenssive but are AWESOME. They are BRIGHT and are BLUE/WHITE....The Headlights are about $50. The DRLs are about $25, Reverse $25, Rear Markers $15, and Fogs $35. You can't get any better either and they have a 3month warranty but I've had mine for 5 with no problems. I had the stupid APC's 1st and I blew literally 1 a day so I switched and havn't had any problems. I even have some water in my Clear corners and the Cuzos aren't affected. I will try to locate some for you on a website. I'll post again if I find something. -Kenny
Old Feb 18, 2003 | 12:17 AM
Look under Bulb Ugrade (Headlight and Acc.) on this website they have them for alot cheaper then I paid. Worth Every penny I paid and espcially at this price. Heres the link Click Me and goto Bulb Upgrades...Hope this helps. Let me know if you need the bulb numbers but I am pretty sure it tells in your owners manual.
Old Feb 18, 2003 | 06:56 AM
ratio411's Avatar
I know this isn't contributing much, but...
Why not show off your clear corners by disabling the DRLs?
Save bulbs, looks, and the corners themselves.
I was in your same boat, paid for clears but had the looks ruined by the DRLs when the car was running. Figured out a good way to disable them, now they look good all the time and are much less of a distraction from the appearance of the car.
If you happen to be interested, I have my disable mod posted on one of the pages on my site. Get there from my sig.
I also have a couple mods that will get you more control over your headlights/fogs. One to get all four forward lights on with your highbeams, instead of just two. Another mod to allow you to run your fogs no matter what you have your headlights set at, even high beam.
They are all very easy and free/cheap.
Good luck
Dave
Old Feb 18, 2003 | 01:38 PM
MeefZ28's Avatar
I got my 3157's (DRLs)from www.midnightmoose.com.
Not Cuzo's (MAX brand) but they're hyperwhite- they should arrive this week. And at 5.99 a bulb, you can't beat the price. If they last only half as long as the cuzo's, I'd still get my money's worth.
Good Luck,
J
Old Feb 18, 2003 | 08:34 PM
mosskeet's Avatar
Thanks a bunch for all the help guys. I'll probably end up going with the Cuzo's since they make all the different sized bulbs which means they should match.
Dave, thanks for the suggestion on the drl. I never thought about them taking away from the appearance of the car. I still want the bulbs so when all my lights are on they will match, but I think I might give your lighting mods a try.
IndyZman
Oct 22, 2015 02:17 PM
Bigfatrat
Parts Wanted
Oct 4, 2015 08:54 PM
Greg88
Sep 20, 2015 07:14 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
