How to remove shifter knob on an auto?
Old Jul 11, 2006 | 08:26 PM
Blue96z28's Avatar
How to remove shifter **** on an auto?
Whats the deal when removing the console, is there a way to seperate the shifter **** from the shaft, if so how? This is an auto trans car im talking about.....
thnx
Old Jul 11, 2006 | 09:04 PM
2000GTP's Avatar
Re: How to remove shifter **** on an auto?
There is a small retaining clip at the back of the shifter ****. It can be pryed out with a small flat-edge pocket screwdriver and the **** will pull right off the shaft.
Old Jul 11, 2006 | 09:14 PM
94_PatriotRed_Z's Avatar
There is a small staple in the front(towards the radio) of the ****. Pull the shifter back to 1st(or 2nd) get a flat head screw drvier or needle nose plyers, and pull the staple out. Then just pull the **** off, but watch out if its the first time you are doinf this because the **** usually sticks and then flys up hitting you in the face. So be careful I learned that the hard way.
Old Jul 11, 2006 | 09:16 PM
GT KILLER's Avatar
LMAO that should've been caught on camera
Old Jul 11, 2006 | 11:25 PM
Brangeta's Avatar
Exactly what he said. That's how you do it.
After you get the staple out, shift it back into park. That way when you pull too hard and it flys off, you'll hit the rear view mirror instead of your face
Old Jul 12, 2006 | 07:46 AM
Blue96z28's Avatar
Thanks for the responses, and the warning on the **** as well LOL
PROJECT X
Apr 17, 2015 12:13 AM
BigWil
Mar 29, 2015 12:24 PM
mattstrike
Mar 11, 2015 07:33 PM
karpetcm
Feb 9, 2015 09:21 PM
tds1213
Nov 27, 2014 12:55 PM
