How to install T/A ground effects
Old Oct 25, 2002 | 10:18 PM
birdlatino's Avatar
Can any body tell me how to install Trans Am ground effects on a Formula. I just got them a week ago .
Old Oct 28, 2002 | 04:50 PM
birdlatino's Avatar
TTT
Old Oct 28, 2002 | 10:24 PM
1994TransAm's Avatar
well the front end is pretty simple, just remove it!!! the rear is the same too, pick up a chiltons manual and it will tell you how.
as for the rocker extensions, you have to cut like 5 or 6 holes along each side of the car for the expanding clips to fit in!
Old Oct 28, 2002 | 10:50 PM
birdlatino's Avatar
I finished the 98+T/A conversion about two months ago , and I just got the side moldings (Ground Effects ) two days ago . Thanks . I thought there was another way to put them on.
Old Oct 29, 2002 | 02:13 AM
neil350's Avatar
I break a peace of mine on a daily basis, so I should be able to tell you.
Old Oct 29, 2002 | 10:48 PM
YammieR6's Avatar
Birdlatino: About how much did it cost you to redo your front end from the 94 Formula style to the 98+ T/A Style??
I have a 94 T/A and im thinking about doing this to mine
Old Oct 30, 2002 | 12:33 AM
birdlatino's Avatar
I spent around $1500 dollars on parts . Both headlights and hood were used the rest was new from my local GM dealer. I also spent another $600 on the rear hatch and rear bumper cover. If you have a T/A then you will not them. It's a direct bolt on . I have all the part numbers if you want them let me know.
Old Oct 30, 2002 | 07:53 PM
YammieR6's Avatar
thanks, sent ya an email Bird
Airplanedoc
Parts Wanted
Apr 18, 2015 04:22 AM
Collector Car
Jan 5, 2015 10:58 AM
troywg
Sep 12, 2002 07:28 PM
Caps94ZODG
22
Jul 30, 2002 08:45 AM
