How do you shut off the DRL's on a 02 TA?
Old Aug 6, 2002 | 12:51 PM
02WS6's Avatar
Post How do you shut off the DRL's on a 02 TA?
I was just wondering how to shut off the DRL's on on 2002 Trans am? I've tried just taking the bulbs out, but then my turn signals don't flash when turned on, and I'm afraid that I might burn out a fuse that way.
-Thanks
2002 WS6
Mods: K&N FIPK
Granatelli MAF
Hypertech Programmer III
160 deg. Powerstat
SLP Loudmouth
Old Aug 6, 2002 | 06:42 PM
silver97Z's Avatar
Arrow
I don't know for sure if it's exactly the same as it was on my '97Z, but if you look on your dash you'll see a little round sensor. Pry up the dash under that sensor and unplug it. Then, fold a paperclip into a horseshoe shape and insert one end into each hole in the plug for the sensor, this will make it think it's daylight all the time and you'll have control over your lights.
Good Luck!
Brian
A4 w/3.73, Hypertech, Loudmouth cat-back, !MAF, K&N cai, air foil, APC clear corners, Voxx Argus 17x9s, Eibach Pro-kit, BMR relocation brackets, BMR adj panhard rod
8.685@80.538
13.561@100.690
Old Aug 7, 2002 | 12:17 AM
PaulN64's Avatar
Post
<font face="Verdana, Arial" size="2">Originally posted by silver97Z:
Good Luck!
</font>
that's the automatic headlight the TA's do not have them b/c of the popup headlights. He's talking about disabling the actualy outside lights. But sorry, dunno how to do it...ask Brent, he has the answer to everything
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
Old Aug 7, 2002 | 01:58 AM
Skull Leader's Avatar
Lightbulb
From the F-body FAQ:
Q: How can I disable my daytime running lights and ambient light sensor?
A: First, gentlty pry off the plastic plate covering the climate controls and stereo. Next, remove the wire cluster(s) from the light and/or convertible top switch (if applicable) so you can get the plastic plate totally out of the way. Then remove the stereo deck with a 7mm socket. You can let it hang and rest on the seat or remove the wire cluster from the back to completely remove it. If you look directly behind where the stereo deck was mounted, you will see a small black box with two wire clusters attatched to the top of it. This is the daytime running light (DRL)/ambient light sensor module. Remove the module from the back of the vent where it's mounted by pulling up and out. Upon inspecting the two wire clusters connected to the module, you will notice one wire cluster on the right is larger and has a black connecting piece, and the one on the left is the smaller wire cluster and has a blue connecting piece. Pull out the smaller wire cluster with the blue connecting piece (you can tape it to the wire or just let it hang). Finally, snap in the module back in place and reasemble your dash board.
It's important not to remove the large wire cluster (black connecting piece) or the whole module itself, as it controls the turn signals as well.
Skull-1 1997 Formula VF-1S
Protoculture:
OBD II LT1 Edit test subject #2, A4 with Motive 3.42s, LT4 Hotcam, G2 LCAs, Hotchkis panhard rod, real Bilstein shocks, Eibach Pros, Flowbastard muffler, ported + polished MAF, Mocoso CAI, Hypertech 160 thermo, TB bypass & airfoil, 1LE sway bars, poly bushings all over, exhaust cutout, BMR STB, 1997 17x9 SS wheels, NKG plugs, big block hood, BBK headers, Jacobs wires, Walbro 255 fuel pump, NX afterburner, times and ET not worth mentioning at 4000ft
I'll chisel your gravestone... sleep well
http://skull-leader.cz28.com
Old Aug 7, 2002 | 02:58 AM
SS 414's Avatar
Post
http://www.xse.com/leres/ss/drl.html
George
2000 Onyx SS #414.
My homepage
Old Aug 7, 2002 | 01:43 PM
silver97Z's Avatar
Talking
<font face="Verdana, Arial" size="2">Originally posted by PaulN64:
</font>
Well...I tried...lol
Old Jun 10, 2003 | 12:15 PM
Drew778/94Z's Avatar
Old Jun 10, 2003 | 06:18 PM
ratio411's Avatar
I did it by jumping a set of wires on the DRL module behind the stereo...
Then again I have a Camaro, don't know if it's a little different for you.
I have instructions on one of my website pages... along with some other little electric mods I have done.
Site in sig.
Dave
Old Jun 13, 2003 | 09:42 PM
ThotYouKnew's Avatar
i just bought like $30 worth of stuff to put DRLs on my 96 z28..haha i love the look..im still workin on getting it installed...i dont know a whole lot about wiring...but ill get it worked out
93 RedBird
Nov 15, 2015 08:24 AM
PopoFormula
Oct 12, 2015 04:19 PM
68camaroboltz
Oct 5, 2015 01:46 PM
KYWes
Sep 26, 2015 08:49 AM
Greg88
Sep 20, 2015 07:14 PM
