How do I install the camaro sport wing?
Old Oct 30, 2002 | 09:41 AM
ExMustangOwner's Avatar
I bought a camaro sport wing used and I don't know if it's missing some bolts. I took off my stock one and I want to know how I bolt the sport wing to the car. Do I use the stock bolts? If I do use the stock ones how do I get them out of the factory wing and into the sport wing? Was it supposed to come with bolts and the person didn't send them? Thanks for you help.
Old Oct 30, 2002 | 11:18 AM
chesee48's Avatar
you should be able to just use the stock bolts...
should be a pretty easy install...
good luck
Old Oct 30, 2002 | 12:10 PM
I can't figure out how to get the stock bolts out of the stock wing and put em in the sport wing.
Old Oct 30, 2002 | 01:06 PM
Eric H's Avatar
Just go up to your local hardware store and pickup some bolts and washers.
-Eric H
Old Oct 30, 2002 | 05:14 PM
naztyz28's Avatar
you cant use the ones from the original wing just go to a hardware store and make sure you use dumdum to seal the hole or it will leak least mine did good luck
hotrodyou1
Dec 20, 2014 10:05 PM
NewsBot
Dec 3, 2014 12:30 PM
Jul 4, 2005 05:00 PM
Gotbass
Aug 2, 2002 11:42 PM
Alucard
Jul 29, 2002 10:30 PM
