How do I get the stickey tape off?
3M has a spray adhesive remover that works well. Available at the auto parts store. You can also use goo-gone or a similar product. WD-40 also works, just a little more clean up involved if you use that.
Whenever I remove badges or stickers or anything like that I use a hair dryer to heat up the glue. Make sure it's good and warm then it should peel off. If it's not peeling off easily enough then use the hair dryer again. I've done that on both cars and that's easily the best method I've come up with. Good luck!
Brian
Brian
Jul 10, 2015 02:23 PM
Brake_L8
Jan 20, 2015 09:44 AM
Stealth Z
Jan 31, 2003 12:43 AM
