HID's
Old Feb 15, 2010 | 09:54 PM
axehead's Avatar
HID's
http://cgi.ebay.com/ebaymotors/1993-...Q5fAccessories
is this ^ a good way to go?
Old Feb 16, 2010 | 12:47 AM
benhart21's Avatar
Not at all. Putting those into halogen housings not designed for that much light output is a bad idea. You'll be able to see ok, but the light will lack focus, cut off, and will have many hot spots. Again, you'll have plenty of output, but anyone facing you will have to deal with all that light. The proper way to do it would be to retrofit some sort of housing or projector that's actually engineered for true HID. For example, here's a projector for an Infiniti that I'm adapting to my Subaru headlight.
I've seen people on here do the Hella projectors that are still halogen, but still greatly improve the lighting. I'm sure with a little searching you could pull up those threads.
Old Feb 16, 2010 | 01:09 AM
benhart21's Avatar
Here's a little something on what I was talking about:
Can I put HID into my stock halogen reflector lighting assembly?
Yes. But it is strongly recommended that you do not. Although it may not seem so, directing the light produced by a headlight bulb to the right places requires a good deal of precision. Reflector assemblies on cars that come equipped with halogen bulbs are made to direct the light produced by halogen bulbs correctly. Replacing those bulbs with HID bulbs that produce three times the light yields a terrible beam pattern. You will have light going all over the place, most importantly into the eyes of drivers of oncoming vehicles. Even if you can tolerate such a beam pattern, your lights would be a safety hazard on the road. Many people try to solve this problem by lowering their lights. However, to reduce glare to acceptable levels, you would have to lower HID lights in halogen reflectors so much that you would not have much of a useable light increase over your stock setup.
http://faqlight.carpassion.info/hl-hid-kits.htm
http://faqlight.carpassion.info/hl-reflectors.htm
If after reading all of that stuff, which I hope you did, you still want to do it, look up the DDM kits. They're half the price of what you posted, have a lifetime warranty, and people on the motorcycle forum I frequent are absolutely gay for them. www.ddmtuning.com
Old Feb 16, 2010 | 08:50 AM
axehead's Avatar
i keep waiting for the price & difficulty in installation to come down. but its just not happeneing.
maybe i should just settle for some silverstars.
Old Feb 16, 2010 | 09:15 AM
95ltslow's Avatar
The only problem i forsee is what projector is small enough to fit the camaro headlights? Havent really had much luck with it.
Old Feb 16, 2010 | 10:01 AM
Chevyssoccer's Avatar
you think the camaro is tight, try when they move too
Old Feb 16, 2010 | 10:49 AM
benhart21's Avatar
That seems to be the biggest hurdle. Like I mentioned though, there have been people that have installed the Hella projectors already. They're not HID, but they're a great improvement over stock. I've also seen pictures of them with HID kits added to them, and they appeared to do a great job of actually focusing the light where it's supposed to be. Here's the thread about it: https://www.camaroz28.com/forums/appearance-34/great-upgrade-those-crappy-headlights-photos-w-62272/
That is most likely the route I will go with my car.
Old Feb 16, 2010 | 01:09 PM
Diplomat's Avatar
Originally Posted by axehead
I spent a crap load of money to do this conversion! 93-97 Camaro don't have a direct headlight replacement. I tried making a unite and best was a fog light that I found in Japan and it worked but not for long. I converted my front end to 98-02. In this I found many verities of units that can be used.
This is what I have now and these headlight are built for HID bulbs.
You can use them on the stokers but the drivers in the other lain are not going to like you and will flash you all the time because it looks like you have you high beams on.
Old Feb 16, 2010 | 01:34 PM
95ltslow's Avatar
That seems to be the biggest hurdle. Like I mentioned though, there have been people that have installed the Hella projectors already. They're not HID, but they're a great improvement over stock. I've also seen pictures of them with HID kits added to them, and they appeared to do a great job of actually focusing the light where it's supposed to be. Here's the thread about it: https://www.camaroz28.com/forums/showthread.php?t=62272
They may do a great job but to me there ugly as hell. I like the lights i have. may just cut the spare set i have open throw hids in them with a shield on top and adjust them so there not all over the road.
Henson071
Dec 30, 2015 09:55 PM
HibachiZ28
Nov 6, 2015 12:53 AM
Henson071
Sep 18, 2015 04:01 PM
Henson071
Aug 4, 2015 09:32 AM
alphaauto
Jul 26, 2015 04:40 PM
