Help with t-top trim
Old Jan 20, 2003 | 08:22 AM
z28sinx's Avatar
The black trim around my t-tops are fading, I need to fix those up. Should I sand and repaint, or is there something I could use to restore those? My friend says sanding and repainting won't work because the paint will crack because of the type of soft plastic around the t-tops. Any suggestions? Thanks.
Old Jan 20, 2003 | 04:33 PM
nothingeined's Avatar
you can try mothers back to black. they also sell the trim that you can repurchase and stuff. hope it helps
Old Jan 20, 2003 | 05:50 PM
superal's Avatar
Yea use the tire spray stuff. Just put some on a rag and wipe it on the trim.
Old Jan 23, 2003 | 12:02 AM
fbird95's Avatar
I use tire dressing. But if you want a real nice permanenat shine, you could clean them and them poly eurothene them. It would be a timely procedure would the results would look pretty sharp.
93 RedBird
Nov 15, 2015 08:24 AM
Hal Fisher
Sep 30, 2015 09:03 PM
Z Power
Sep 19, 2015 11:19 PM
tdigger9899
Sep 7, 2015 10:56 AM
