help on cluster remozal
Old Feb 13, 2005 | 02:14 PM
carbed94z28's Avatar
I got a 94 z28 that I put a carbed sbc in, I'm gettin ready to put all my auto meter gauges in but I'm not sure how to remove the cluster, I believe the trim is just held in by clips but I was wondering where they are so that I don't break any of the trim pieces in the process of trying to get the cluster out. any help would be greatly appreciated.
Old Feb 14, 2005 | 12:47 AM
Z95m6's Avatar
Re: help on cluster remozal
93-96 camaro dashes are the worse thats one of the reason why i installed a TA dash. You have to remove the a-pillars then the plastic dash top. After that open the glove box and take out the bolts that hold on the trim for the Radio. Then drop the panel under the column and remove the remaining bolts that hold the radio trim on. Now you can start removing all the bolts that hold the trim on around the cluster. After you remove the dash trim you just have 5 more bolts to go to get the cluster out. Its been a while but i believe thats everything. Good luck.
Old Feb 14, 2005 | 06:49 AM
SplitFire's Avatar
Check the link in my sig
IndyZman
Oct 22, 2015 02:17 PM
4586
Aug 24, 2015 11:04 PM
4586
Aug 13, 2015 10:11 PM
maybe2fast
Feb 27, 2015 08:09 AM
rwferguson43026
Feb 6, 2015 10:06 AM
