hella light bulbs...
Old Jan 23, 2006 | 09:15 PM
DiabloGT's Avatar
http://lightingresearch.com/store/pr...products_id=59 for the lows 80watts, http://lightingresearch.com/store/pr...products_id=58 for the highs 100watts, will those fit with the hella ff75's? and what should i do for the fogs since there hella ff75's or do i have to use h7 bulbs instead of 9006 and 9005
Old Jan 23, 2006 | 10:15 PM
Bud M's Avatar
Re: hella light bulbs...
FF75s take H7 bulbs
http://www.rallylights.com/hella/H7.asp
Old Jan 23, 2006 | 11:04 PM
DiabloGT's Avatar
what about these: http://lightingresearch.com/store/pr...products_id=72
in 100 watts for the highs, is 100 watts for the fogs too much? and is there any place that sells like 80 watts for less than like $8 each?
thanks
p.s. what do you think of these : http://lightingresearch.com/store/pr...products_id=95
and if i buy the headlight hellas do they work the same way as the fog lights?
Old Jan 24, 2006 | 08:27 AM
94BlackBowtie's Avatar
thanks
First off - do some some reading. I think I have seen you post in some FF75 threads - so you should be a little wise on the subject. They have been mentioned quite a bit here lately. And so have their bulbs.
Secondly - Lighting Research is the cheapest place for bulbs - and they have the highest output clear bulbs for the lowest price for the FF75's (generally speaking) which is the H7 Luks in 100w (the 1st link you posted in what I quoted).
The driving FF75's and fog FF75's are different.
http://www.pilotautomotive.com/beam.htm
Search this forum section for FF75 and for bulbs and do some reading. If you want to learn. If you just want an answer, then I guess you'll probably get there this way.
If you want Hella bulbs - which are the BEST, then get some TRUE Hella's (not Optilux) from the link Bud posted.
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
thenewkid
Nov 29, 2014 04:54 PM
