headliner
Old Jun 7, 2007 | 06:45 AM
snareman's Avatar
headliner
anyone know where there is a write up in changing headliner in a 93z. dont wanna pay 150 bucks.
Old Jun 7, 2007 | 08:16 AM
shock6906's Avatar
Any headliner writeup will do. It's all the same in practice, just the procedures for removing the shell are different. Is this a T-top or hardtop car?
Old Jun 7, 2007 | 11:07 AM
snareman's Avatar
headliner
its a 93z28, without t-tops. so it has the t-tops bar in the middle. I just need the writeup on how to do it and a place to buy the headliner.
Old Jun 7, 2007 | 11:58 AM
transAMdriv3r's Avatar
Pretty easy to do, will only take about 1 hour. What you need to do is take off both sun visors (3 phillips in each) then pry off the a pillars, remove the coat hangers on the c post along with the plastic clip around the seat belt which is near the top on the c post.(becarefull very easy to break). the pry the c post down a little bit
Finally take off the over head light near the hatch and carefully pull the headliner it out through the hatch. your done
>>>>>you can get your headliner reupholstered for around 50 bucks.
Old Jun 7, 2007 | 12:11 PM
shock6906's Avatar
Correct, if you do the R&R part yourself. If you have the shop you take it to do the removing and replacing of the shell, it'll cost 150ish.
football4life
Oct 4, 2015 07:48 AM
Daluchman1974
Sep 11, 2015 06:12 AM
92_RS_305
Sep 8, 2015 07:47 PM
scottcba1
Sep 8, 2015 09:52 AM
TGGodfrey
Aug 17, 2015 08:43 PM
