headlights
Old Nov 19, 2002 | 01:46 AM
Miles-'s Avatar
headlights
I know there have been some posts about changing the lights on camaro's. I have already changed them once by pulling the lights out of the housing and putting in new bulbs. I went with some cheap cool blue lights and they looked pretty good and were as good as stock maybe a little better. However they burnt out already and I want to know what are the best ones to put back in there. I do not want to change the housings and do any modifications. I just want a 9005 bulb that will give the best output. Please name some specific brands wattage etc that have worked on your cars. and where to get them as well
thanks in advance
Old Nov 19, 2002 | 01:29 PM
nothingeined's Avatar
i have naxos. they are rated at 80 watts. i dont know if that is good our bad. they give off a real nice light blue light. they werent bad for 30 bucks.
Old Nov 19, 2002 | 01:35 PM
94BlackBowtie's Avatar
The Sylvania Silverstars are very white/bright. I recommend getting them, but be ready to fork out about $60 a set...BTW, the low beams are 9006's...
Old Nov 19, 2002 | 02:11 PM
AW/whiteZ-28's Avatar
Yea i have silver stars too they are great they look purpleish gray
from far away and look really clear up close
Old Nov 19, 2002 | 03:03 PM
onoiocoko's Avatar
did u touch the bulb? cause some bulbs say that they will burn out if u touch the glass with ur bare fingers. or it might of just been the bulbs. i dont know much about lights just letting u know if u get a nother set try putting them in different. how did u guys put them in a towel? or just ur fingers?
Old Nov 20, 2002 | 02:05 AM
Miles-'s Avatar
thanks for the replies, no i was real careful not to touch the bulbs, I think they were just some cheap light that I got a bad set. I tried to get a replacement but they would not do it. oh well just get something else
Old Nov 20, 2002 | 06:59 AM
Originally posted by onoiocoko
...cause some bulbs say that they will burn out if u touch the glass with ur bare fingers...how did u guys put them in a towel? or just ur fingers?
Just about all of them will burn out shortly after installation if you touch the bulb...the gas burn very hot in them and the oil from your fingers/skin causes it to heat up differently and all kinds of stuff, and it just blows them...don't touch the glass.
I just always hold them by the plastic base and install them. If I am worried about touching the glass accidentally, I just use anything clean and cloth that will be a fail-safe for me.
Greg88
Sep 20, 2015 07:14 PM
Henson071
Sep 18, 2015 04:01 PM
jackpawt883
Sep 10, 2015 08:53 PM
Aug 17, 2015 09:50 AM
Henson071
Aug 4, 2015 09:32 AM
