halo lights
Old Jan 13, 2004 | 09:46 PM
rez101's Avatar
halo lights
hello all I am thinking about getting a set of halo lights for my z and I was wondering just a couple things I have the xenon bulbs in my car now will I be able to use those or do I have to replace them also the halo light is that something that comes on only when I put my running lights on or is it on only when my headlights are thanks again
Old Jan 13, 2004 | 10:24 PM
AW/whiteZ-28's Avatar
Yes you can use a stock sized bulb and the halo turns on with whatever you wire it to ie: running lights, headlights,stand alone switch, or foglights
Direct bolt in replacement as long as you are familiar with connecting wires and spliceing into existing wires should take an hour at the most to install them
Old Sep 7, 2004 | 11:16 AM
Pabz2k1's Avatar
Re: halo lights
Yeah, I got the halo headlights on my 2k1 Camaro. The only problem is that the driver side halo is out. Does anyone know how to fix it? I checked the wiring and it's still connected. I connected them to the side markers. Any suggesstions.....
Old Sep 7, 2004 | 12:29 PM
Re: halo lights
See if you can get a close up pic of where the wires to the halo go in and see what bulb or led is actually lighting it up you might be able to put in another led instead of buying a new headlight just cause the halo went out...
PROJECT X
Apr 17, 2015 12:13 AM
Jlo
Feb 3, 2015 09:41 PM
squarehead
Jan 15, 2015 07:02 PM
stars1010
Jul 17, 2002 04:36 PM
