Got my rims on
Old Feb 17, 2004 | 08:06 PM
Standard-z's Avatar
Got my rims on
Hey gang got my tires 275 17's on with 35th anniv rims.
Sorry no pics. No camera
There should be a guy on here with 1 the same as mine
My car is a 96 red z.
? Now i just installed these.Is it good to get an aligment?
Also do i need to do any thing to the Tach?
Old Feb 17, 2004 | 08:29 PM
30thANNIVZ-28's Avatar
The tach will be fine 275/40/17 is the correct plus sizing from stock 245/50/16. If you were to put the stockers and the new wheels next to each other they would be the same height.
As for the alignment dont think you really need one but if its been awhile might as well get it done since 17in tires do cost more than 16s.
Old Feb 17, 2004 | 08:44 PM
Standard-z's Avatar
Ok thanks. I forgot to mentioned i went from 255 50 16
to the 275's
Old Feb 17, 2004 | 08:45 PM
Zack's Avatar
look at your old tires. if they look like they are wearing more on the inside/outsides, then you would want to get an alignment
Old Feb 17, 2004 | 10:40 PM
Well teh car was set for 245/50s from the factory. So when you had the 255 50s is when you should have done something about the tach. The car was set up for 245/50 so the 275/40 is a direct swap.
Old Feb 17, 2004 | 10:51 PM
lbls1's Avatar
You should always get an alignment with new wheels. Good going on them, I've got a set on right now.
If you came with 16's from the factory and now you've got 17's you might want to look into getting the speedo recalibrated, or at least checked. A lot of z's go from the stock 16's to oem 17's, and I haven't heard of any of those guys having their speedometer checked. Then again, I guess alot of people don't do this either.
Good luck. I like the 35th anniv. rims alot.
Old Feb 18, 2004 | 07:28 PM
Standard-z's Avatar
Thanks guys.. No my old tire are only 2 years old.
So not worn bad. I think
G-BODYT56
Jan 14, 2022 11:14 PM
IndyZman
Oct 22, 2015 02:17 PM
Formula Steve
Sep 19, 2015 08:48 PM
rvonsternberg
Sep 14, 2015 11:58 AM
scottcba1
Sep 8, 2015 09:52 AM
