Gold Series Neon Install- 97 Camaro
I just bought the Gold series neon package from StreetGlow and was wondering if anyone could help me w/ installation instructions; I have no idea what all is required, and i've heard the Gold series is more difficult since it's larger (than blue).
Also, I really really want the bulbs to be concealed and hidden from outside viewing.
Please reply or email me w/ any help you can offer. thanks guys,
Jay
JayBaste7@aol.com
Jay
JayBaste7@aol.com
the front and back neons aren't that hard to do. The sides are the tricky ones. You will most likely need a lift in order to install these inside the frame and here's why. To get the side tubes inside the frame, you will have to hold towards the front of the car at a downward angle and push at an upward angle to get the neon tube past the LCA bolt. You'll have to push it through past the bolt and start pusing the neon tube up and pulling forward at the same time. You will have to get the tube to touch the cross member right were the fuel lines are being held. You may want to run the neon wire over the fuel lines as you go up. Mark the holes and pre-drill them but be sure to take the tube out of the way. If you need more help as far as running the wires, email me and I can send you back a more detailed instructions.
1997 Camaro Z-28 SS #0728
Flowmaster, Hooker Header tips, BMR strut tower brace, lower control arm and relocation bracket, Optima Yellow Top battery, Granatelli lowering springs, KYB AGX shocks, Lakewood panhard rod, Bear bump steer, 17 x 9.5 Z06 rims
Audio/Video:
Head Unit ----- Pioneer AVX-P7000CD
Master Unit --- Pioneer AVM-P9000R
DVD Player ---- Pioneer XDV-P9
Front --- Focal Polykevlar 165K2 w/ TN-51 tweeters
Rear ---- Focal Polykevlar 165K2
Sub ----- Lightning Audio 10.2.4
Amp ----- Phoenix Gold XS6600
My SS homepage
CAR AUDIO PLANET
Georgia F-Body Association
Audio/Video:
My SS homepage
CAR AUDIO PLANET
Zomie
Jul 22, 2002 03:34 AM
