glasstech hood install problem
Old Apr 4, 2004 | 11:56 PM
bbz28's Avatar
while the hood lines up pretty nice on each side but there are a couple of problems:
1. Before I installed the hood latch & release lever the hood is slightly too far back on the passenger side (3/16") yet both sides are evenly spaced.
2. When I installed the latch & release lever the hood on the passenger side doesn't go all the way down flush even with the fender. I've removed the 2 rubber, round "stops" and it improved somewhat. also, when I do close the hood all the way down the hook doesn't want to release.
Sound familiar?
thanks,
jerry
Old Apr 5, 2004 | 09:19 AM
Brent94Z's Avatar
Super Moderator
Hey Jerry, from what I've seen, it is always in install issue. Glasstech is a good company and sells tons of hoods so I'd have to think their mold is correct.
I've seen some hoods that look like they were made for a different car after the car owner installed the hood and spent hours trying to align it. Looked terrible. After finally giving up and thinking he got a poorly made hood, he took it to a body shop and they aligned the same hood and it looked better than factory
I know aligning a hood is difficult if several adjustments are needed. Before giving up entirely on the hood, you might want to consider taking it to a GOOD body shop and see if they can assist you.
Good luck!
F'n1996Z28SS
Aug 23, 2023 11:19 PM
Oncomingstorm22
Jan 22, 2015 07:15 PM
CARiD
Jan 14, 2015 04:00 AM
89 iroc zl1
3rd Gen / L98 Engine Tech
Jan 14, 2015 02:18 AM
