gauge cluster removal
Old Dec 28, 2004 | 11:20 AM
stone150's Avatar
ok i am trying to replace my 96 gauges with 97's, i unbolted everying, but somehow the 96 gauges are still held in there, is it the wiring harness that is holding it in? do i just yank it out or what? thanks
Old Dec 29, 2004 | 03:37 PM
camaro 22's Avatar
Re: gauge cluster removal
I've done this many times. Make sure all the screws are out, and just pull it towards you. The harness is connected into the back, so just pull. Good luck.
Old Dec 30, 2004 | 06:12 PM
stone150's Avatar
will i be able to pull the wires out farther to be able to later connect it to the new one?
Old Dec 30, 2004 | 09:12 PM
camaro 22's Avatar
The wires stay in place. they're connected to the dash itself behind the cluster. When you put the cluster back in, you just push it straight back, and the wires will connect then. You'll see how it's set up once you remove the cluster.
Old Dec 31, 2004 | 01:27 PM
stone150's Avatar
oh ok, i thought they would just pull out with the cluster, someone told me there were some clips or something, but i just need to pull strait out, then just push strait back it? thanks
Old Dec 31, 2004 | 05:47 PM
DiabloGT's Avatar
what it all just fits right in? i thought it was way more than just the speedometer gauge part, like differnet wires, and hook ups and stuff like that?
Old Dec 31, 2004 | 05:57 PM
Z95m6's Avatar
These guys have Trans Am dashes and 97+ Camaro Dashes they are pretty much the same.
Once you get the bolts out that hold it in place you just yank hard on it and it will unplug and come out. Also stone150 are you interested in selling your old cluster? I just swapped a 93 Trans Am dash into my car and the 93 cluster trip odometer doesn't work half the time. A little thing i know but i like to have one. I also think the 94-96 dashes are diff too. Let me know. Thanks
Old Jan 1, 2005 | 12:42 PM
stone150's Avatar
i might keep the original, just bec i will keep the car as a collectors thing and i try to keep all my stock parts, but who knows i will get to the point of having too much crap in my room.
mattstrike
Mar 11, 2015 07:33 PM
94Camaro
Feb 28, 2015 03:00 PM
Joes96z
Dec 13, 2014 07:48 PM
CaRParts102
Dec 6, 2014 08:45 AM
