Gauge cluster ?
Old Jul 18, 2002 | 10:47 PM
redcamaro9090's Avatar
Post Gauge cluster ?
I didn't know where to put this but it's somehow related to appearance. I have the 110mph gauge cluster in my car now, say I buy a 150mph gauge cluster, would it hook right up and would the numbers be off? Now this is all to me wanting Indiglo gauges and not finding any good ones for my 110mph gauge. Thanks for your help!
Old Jul 18, 2002 | 11:09 PM
ZForce's Avatar
Post
I put a Z28 (150mph) gauge cluster in a friends V6 (120mph)camaro and installed the Indiglo gauges. His car is a 99 and I just got a 99 Z28 gauge cluster and it went right in and everything worked. The MPH even read correct. Only problem he had was the air bag light came on and stayed on. I'm not sure if the earlier camaros will be that easy or not.
Robert
1998 Camaro Z-28 M6
MODIFICATIONS
Engine: GMS Lid, FTRA, TByrne Red MAF Ends, BBK 80mm TB, 160* Thermo, 1 piece TB Bypass, SLP Fan Control Switch w/LED's
Drivetrain: SLP Short Throw Shifter, Lou's Short Stick w/ROBMOD, !CAGS
Suspension: BMR Dbl. Adjustable PHB, BMR LCA, BMR STB, KVR Cross Drilled (F/R)
Appearance: SLP Bowtie Grille, Clear Corners, T/A Power Antenna, Tinted Windows, Zaino
13.24 @107.75 w/2.17 60'
311rwhp / 328rwtq Dyno Graph
Pictures
Old Aug 31, 2003 | 07:45 AM
uncsam's Avatar
ZForce, how much trouble did you have changing them out?
Unc. Sam
Old Aug 31, 2003 | 08:57 AM
JASON5's Avatar
i did the same thing to my 96 v6 camaro, it plugged right in, everything will work except for the rpms, it willl be off 20 - 25%
Formula Steve
Sep 19, 2023 08:31 AM
IndyZman
Oct 22, 2015 02:17 PM
drt
Sep 27, 2015 04:39 PM
RX Speed Works
Sep 11, 2015 03:31 PM
jackpawt883
Sep 10, 2015 08:53 PM
